Virtusa Consulting Services Pvt. Ltd.
Last activity: 7 Nov 2019 20:28 EST
java.lang.RuntimeException: Component stack mismatch
Our application has been upgraded to 7.3.1 an year ago and since then, on a random basis, users are getting Harness failure error. When verified in logs, we saw a RunTimeException which says,
java.lang.RuntimeException: Component stack mismatch {"section":"XXXX","ver":"1","objClass":"Rule-HTML-Section","class":"XX-YY-ZZ","RO":"false","sectionBaseRef":"","expandRL":"","UID":"SID1548168960812","outerGadget":"GID_1548168960803","pyName":"pxSection","pyTemplates":[{"NTId":"1548168960810000","NTRef":"377a281255308411b9d9c369082c39b9_2","pyName":"pxNonTemplate"}]}!!!!===={"containerType":"CENTER","isClientWhen":false,"isVisibilityOption":"","pyName":"pxHarnessContainer","pyTemplates":[{"whenId":"3446558839592bbdd282724cb6956d2e_4","pyName":"pxVisible","pyTemplates":[{"NTId":"1548168960776000","NTRef":"8bb8687bb6525f4960bf3d5bee28fae1_1","pyName":"pxNonTemplate"}]},{"pxReferencedId":"3446558839592bbdd282724cb6956d2e_5","pyName":"pxSection"}]}
This being random, we are not able to pinpoint the issue. Also, it is occurring in several places of the application but the common part is that, the sections have a repeating list in the form of a Table or row repeat etc.,
So, I wanted to check here before raising an SR. Anyone who has faced this issue and found a solution, please suggest.
Thanks in advance!!
The issue was with failed when rule in the section. There was a RuntimeException around the same time which had the rootcause pointed at.
Hi ,
Complete logs may help.
Please find attached log instance of that issue
Areteans
Hope this might help you:
I have gone through this conversation before raising this question. That speaks about 8.1.3 patch for which we do not have plans for.
Can you confirm if you are getting harness related(eg: NullpointerException) errors related to "DisplayharnessWithClass". Also, please share with us the complete logs.
I do not see any such error before or after this issue.
Hi ,Have you tried revalidating and saving ? Sometimes issues like these gets resolved by revalidating those sections .
or Do a private edit and save that and check if the exception is still appearing .
Intentionally, I am not able to reproduce it but, there are multiple instances of this issue in the logs every day.
Centene
Can you please elaborate ?
We too have the similar exception and a runtime exception but not able to find any missing rule in the exception log.
