Accenture
IT
Last activity: 2 Mar 2019 22:35 EST
SMSC connection settings
Hi all,
we are trying to configure an outbound SMPP connection to an SMSC account but it gets refused. Pega is able to communicate to SMSC server but Pega connection gets refused with the following error:
Exception caught connecting to SMS server; ie.ncl.msg.ConnectionException: Cannot connect - Invalid password OR bind failed because bind limit has been exceeded Disconnected successfully from SMS server.
With an external system we found the correct list of SMPP parameters that work for binding the connection:
group = smsc
smsc = smpp
alt-charset = "UTF-8"
smsc-id = 7659
smsc-username = ****
smsc-password = *****
system-type = "smpp"
allowed-smsc-id = 7659
host = ****
port = 4001
transceiver-mode = 1
wait-ack = 30
my-number = 2719
dest-addr-ton = 0
dest-addr-npi = 1
source-addr-ton = 5
source-addr-npi = 0
address-range = *
Hi all,
group = smsc
smsc = smpp
smsc-id = 7659
host = ****
port = 4001
wait-ack = 30
my-number = 2719
dest-addr-ton = 0
dest-addr-npi = 1
source-addr-ton = 5
source-addr-npi = 0
address-range = *
bind-addr-ton = 1
We then tried to replicate the same set in Pega: some parameters have to be added in the "Additional settings" tab but if we do we get the error:
Not valid property name
The questiona are:
- is there a naming convention for SMPP properties to be added in the "Additional settings"?
- Looks like the "-" character is not supported by Pega and the traditional escaping codes do not work, how to escape that sign?
Thanks in advance
