Lloyds Banking Group PLC
Last activity: 30 Oct 2019 3:08 EDT
Container title based on Parameter
Hi, I have a parameter CustomerName (Param.CustomerName) for a section. I want to display the value of customer name as header title. There are 3 options in container settings. Which one to choose and how to implement it?
We can use the property and provide the Param.CustomerName value.
For more info please refer below articles:
Thanks for the response Praveen.
1) I have tried with Property as shown below.
when i try to save section, got below error.
2) I have gone through the both reference links you have provided.
https://docs-previous.pega.com/how-use-parameters-section-rules
Above URL explains about how we can implement in V5.4SP2, but the same approach is not working in 7.3.1
https://collaborate.pega.com/question/cannot-use-section-parameter
Above URL suggests that there is a defect in the Pega product, would you please suggest how can we achieve in 7.3 / 7.4? or raising SR is the only way?
You can raise the SR for the same.
Hi Venkatesh,
Can you attach the screenshot showing how and from where you are passing this parameter to the section.
Also please let us know the version of Pega that you are using.
Basically you have two options to pass the parameter to a section:
Standard— Parameter values are supplied at runtime by a parameter clipboard page.Advanced— Parameter values are based on specialized gadgets to support landing page operations.
Please check the below for the same:
Hi Venkatesh,
Vikash
Trina Roy
Hi Vikash,
I am working on 7.3.1
Below is screenshot for parameter configuration:
Thanks & Regards,
Venkatesh
Have you configured a section include in which you are passing the parameter?
could you also attach the screen-shot from where you are passing the parameter to the section.
Hi Vikash, I have a flow action in which i am calling section and passing parameter value from flow action itself.
Hi Venkatesh,
I have configured everything based on your description in same Pega version and got the same error.
It looks like a bug and you can raise a Support request to get this thing fixed.
Vikash
TechMahindra
Hi Venkatesh,
I am also facing same issue in V8.2. Did you raise SR? Any solutions found?
Karthick
Bits In Glass India Pvt Ltd
Hi Venkatesh,
Can you please share the screenshot of the activity or data transform where you are setting the value and passing it to section? Because I have implemented the same thing, and that was working fine.
For this you can take the references of these article -
https://community.pega.com/knowledgebase/articles/how-use-parameters-section-rules
Thanks.
Hi Ayan, May I know the version you have tried and it worked?
Thanks & Regards,
Venkatesh
LTIMindtree
Is there any solution available for this .. i tried in the similar way as explained above
1. made the param as out param in pre activity of a flow action.
2. same parameter i defimed in the container settings in the section rule , in the section rule i made it parameterized with option standard.
its throwing below error
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
P3Fusion
Any solution for this query? i have been asked this scenario in LSA readiness exam and i am looking for the solution.
Regards
Praveen
