Capgemini
NO
Last activity: 10 Jun 2019 9:06 EDT
What are different ways to Generate PDF (of a section) other than EForm to keep the layout as it is?
Note : I have tried HTMLToPDF. It doesn't keeps the layout as formatted in the section.
I am using Pega 8.1 where there is no Free Form Layout or Smart Layout.
Likes (2)
Vamsi Krishna Chukkapalli Atikant Sinha -
hi,
Are you stating that using the layout format like inline/inline grid is not displaying as required in the PD when you are using the HTML TO PDF smar shape ?
(If this correct then we will be checking the same inhouse and proceed further)
Capgemini
NO
Yes, all the fields are appearing vertically in the pdf. Not as per section layout.
Mattia Rosellini
Areteans
Hi @Piyush,
As far as I know the CSS referred in the section can't be available for the PDF.
So you need to either write custom HTML or use Paragraph rules in Section to get the desired output.
We have used freefrom layouts in Pega 7.x versions and it works but with some customization using embedded styling(not CSS classes).
Kamalesh
Can you please refer my post. I have given the sample example of converting Section to PDF using OOTB "HTMLTOPDF" activity.
https://collaborate.pega.com/question/show-section-pdf-format-button
Please let me know in case of any questions.
Capgemini
NO
I have also tried HTMLToPDF. As mentioned in the question, it doesn't uses the skin/css of the section.
EvonSys India Pvt Ltd
You can try pxCreatePDF also
CNO
Is using Eform good option?
Evonsys
Abener Ochoa
