![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689975000/44e38393-cfef-4670-ad19-4f0261e6d588.jpg?itok=sS-83qPx)
Freelancer
CH
Last activity: 29 Jun 2020 23:46 EDT
Correction: Fixed Header / Layout group tabbed header fix while scrolling
Hi Pega Community ,
they are two questions which are closed without any solution or help:
https://community1.pega.com/community/pega-product-support/question/fixed-header
To solve this problem you need do do a local change ( I quest with higher version from Pega 7.2.1 on its already solved).
I tested in Pega 7.2
To have a fixed tab header ( or have a sticky header ) you need to add this code snippet in UserWorkForm
<style>
.Masthead > .scrlCntr {
text-align: left;
overflow: hidden;
position: fixed;
width: 89%;
top: 5%;
.Masthead > .tabContent {
border: none;
margin-top: 30px;
</style>
In this example Masthead is the styleformat of the Tab Group properties ( If you resaved the Skinrule from pyEndUser71 then you will have this styleformat - select in the dropdown others and give Masthead) . Otherwhise create or use your custom one and make sure that is used only for the Tabheader style - otherwhise it can destroy other tabs - , please make then sure that you also define the tabs like this ootb section which is refered from the body screen layout : pzStudioContainerTabs)
Regards
Ufuk
