Tech Mahindra
Last activity: 2 Sep 2019 10:55 EDT
SummeryReport
Here i calculate sum (one property) in reportdefination , here i take sum option summarize column it show correct answer, but here i will face some issue. Reportdefination take into a section(table layout) it not show all data because in summarize column i will take sum . So in Reportdefination calculate sum of every property is there any another way.
Areteans
Hi Bhavani,
Thank you for providing the information.
We cannot use Summarized RD in table layout. only list based RD's can be sourced.
To achieve this, you need to use Hierarchical table layout.
Bala
Areteans
Hi Bhavani,
I have tried replicating the above scenario and it is working as expected. the only difference I noticed is pagination is not getting applied.
Could you help me with below details for further analysis,
1) Pega Version
2) RD screenshot
3) Table layout design configuration screenshots
4) screen shot table layout at runtime(with Data)
Bala
Balaji E S
Tech Mahindra
I will attach the file below
iT how to generate a summary report.Can I use use this report in Section by giving the source as Report Definition.I have given the Report definition in Table layout in section ,but it is showning the following error as pyRDName—pyGridDoesNotSupportSummaryTypeRD.
Is there any possibility to display the summarized report in Section.
Thanks in advance.
bhavani
Areteans
Hi Bhavani,
Bala
Tech Mahindra
Thanku for reply,
Here i use hireracy table and it work .
Thanku very much,
bhavani.
Tech Mahindra
Hi Bala,
Hierarchical table layout is working fine but in Data Table the records are not getting displayed and showing the below error(Attachments).
Hope you can help me with this too.
Thank you in advance.
Regards
Bhavani.
Kiran Chitmalla SK SHAHIR HALIM Nageswara Rao Kaja
Areteans
Hi Bhavani,
The error is not due to Hierarchical table representation of data. It is because of the summarized report definition.
As per the error, I could understand that Summarized RD may not support this. You may need to change the RD.
Bala
