Knowledge Expert
FR
Last activity: 24 Jan 2019 3:06 EST
Mashup size dynamically to avoid scrollbar
My customer wants to display a Pega application into mashup gadget.
And he wants to display only the brower scrollbar and not the scrollbar generated by the pega application.
The only way I find to implement this is to fixed the size the mashup gadget with the exactly size used by the pega application... But this size depends to the displayed harness.
Do you know if it's possible to dynamically size the mashup gadget to avoid display the application scrollbar?
Or do you know if another implementation provides this behavior ?
Exemple of implementation and mashup size results :
- Configuration : Fix size of mashup gadget
<script src ='https://XXX/prweb?pyActivity=pzIncludeMashupScripts'></script> <div id="PegaMashup" style="overflow:auto; width:1450px; height:3000px; display:block;" data-pega-gadgetname ='PegaMashup' data-pega-action ='OpenWorkByURL' data-pega-action-param-query ='pyActivity=Data-Portal.ShowDesktop' data-pega-action-param-parameters ={UserIdentifier:'[page/id/Account]',Password:'[page/id/EncodedPassword]'} data-pega-isdeferloaded ='true' data-pega-applicationname ='AssurVieCA' data-pega-threadname ='STANDARD' data-pega-systemid ='pega_dev' data-pega-resizetype ='fixed' data-pega-url ='https://XXX/prweb/IAC' data-pega-event-onload = "onLoadFunc" data-pega-redirectguests ='true' ></div>Results : Mashup doesn't include scrollbar but the browser scrollbar is not dynamically (in this case, always 3000px):
- Configuration : Dynamic size of mashup
<script src ='https://XXX/prweb?pyActivity=pzIncludeMashupScripts'></script> <div id="PegaMashup" style="overflow:auto; display:block;" data-pega-gadgetname ='PegaMashup' data-pega-action ='OpenWorkByURL' data-pega-action-param-query ='pyActivity=Data-Portal.ShowDesktop' data-pega-action-param-parameters ={UserIdentifier:'[page/id/Account]',Password:'[page/id/EncodedPassword]'} data-pega-isdeferloaded ='true' data-pega-applicationname ='AssurVieCA' data-pega-threadname ='STANDARD' data-pega-systemid ='pega_dev' data-pega-resizetype ='stretch' data-pega-url ='https://XXX/prweb/IAC' data-pega-event-onload = "onLoadFunc" data-pega-redirectguests ='true' ></div>Results : Mashup includes scrollbar and browser displays scrollbar
For information (or test), current implementation of the mashup page in attachment (with a test to get pega data with getGadgetData but doesn't work curently).
Thanks in advance,
Johan
The customer needs have changed because he wants to use an iframe to include the pega application.
We have found a solution but it doesn't depends to Pega core so I don't create the SR.
For information, the implemented solution will be the following :
