Atos Syntel
Last activity: 28 May 2019 2:24 EDT
Is there a way to Load balance Queue traffic for Agents(running in a cluster) versions prior to 7.3 ?
RunOnAllNodes
The final set of servers is classified as RunOnAllNodes, which informs Pega 7.3 to run the agent on all nodes (either simultaneously or on one node only at a time) to properly handle the volume of requests. For example, in a high transactional environment where thousands of transactions take place every hour or even every minute, you may require additional processing steps to complete the transaction and also to keep up with the volume. Load balancing this process across many nodes ensures that each transaction completes on time. Splitting the workload across many nodes may often be needed; the use of RunOnAllNodes is specifically for this purpose.
Is it possible to achieve this load balancing/ some other load balancing on Agent which runs in a cluster for versions prior to 7.3 ?
