Areateans Technology
Last activity: 30 Apr 2019 12:43 EDT
Dashboard gadget/widget can't be moved via drag&drop
I have created a new dashoard widget/gadget that works well. The only thing missing is the drag&drop capability that allows me to relocate the widget/gadget within the Dashboard Slot.
Any idea what needs to be added to the section to enable the drag&drop capability?
Hi
are you getting an JS error while trying to perform the activity.
I don't get a JS error. When clicking on the gadget and while keeping the mouse button down, only the HTML of the page is selected. The orange indicator to drag&drop the widget doesn't appear.
Thanks for the reply. Which browser you are on? Also, is the behavior same in all other system?
Could you please share your SR ID with us so that we may track?
Thank you!
Ok. Thanks for letting us know.
Updated: 30 Jan 2019 9:23 EST
It is SR-C84353. Probably won't be fixed for current releases. Most likely in a future release.
Thanks @TERIR,
I'm showing your SR was resolved with this:
Perform the following local-change:
Use open and close, multiline comment syntax for comments in the JS code where comments are required.
For example use:
instead of :
Thanks @TERIR,
For example use:
instead of :
Please review SA-72436 Click and drag custom dashboard gadget does not work if you have the same question as this SA was generated as a resolution for the associated SR.
