Wipro
Wipro
Wipro
Posted: Jan 2, 2019
Last activity: Jan 18, 2019
Last activity: 18 Jan 2019 15:04 EST
Trying to execute the jenkins job in the pipeline.getting the below attached error in the jenkins job - console output.
Hi Rajeswari,
Looks like you have issues with the execution of the curl command as shown in the attachment. You can make sure to cross check with the sample curl command execution running successfully or not from your command prompt. I tried to search in web for the reasons behind this error and found couple of discussions which might help you as follows,
https://stackoverflow.com/questions/40142279/execute-curl-from-jenkins
Hope this might help you to proceed further on this issue.
Mahesh M
Thanks for the reply.We are creating a Maven project (job in jenkins) .After troble shooting ,identified that Curl and maven is not installed in the machine the job is running.
We are working on the installation and once done will check running the pipeline again.
Let us know if you are still looking for help on this issue, or did the proper Maven installation fixed your issue?
