Can you use Xendesktop 7. X VDI with PEGA?
You can assign 1 user account as a windows assisted sign on AND you can assign a user account in the windows vault that acts as a user carrying out the automated process. So, 1 account to login and 1 account local to the VDI to carry out tasks. This is not a central configuration. How does this scale? You cannot image this concept and deploy from image. You will have machines all using the same windows login and same accounts to run the applications if you deploy from image. This will be an issue for licensing and session control. Can someone enlighten me how this approach is tackled?I am looking to use Pega on Xendesktop VDI. Is this possible?
