Singtel Optus Pty Ltd
Last activity: 13 Nov 2018 13:18 EST
Proposition Mappings not reflecting the updated values while running the SOAP tests
The proposition mapping is getting updated in Lower environment and deployed in Production as a BAU deployment. But when the SOAP tests are run we are not getting some of the xml tags populated in the SOAP response even though the proposition mapping has got those tags.(For example :Component details) but when we do a checkout & checkin of the Decision Data records for that Business issue then the SOAP response is populating those xml tags. There is a kind of inconsistency which results in the issue. Not sure if this is a proposition cache refresh issue.
Also the Data page which is the source for the API calls for the proposition mapping instances are defined at Node level with a refresh strategy of 5 mins. Not sure how check out & Check in of records fixes the problem.
Any assistance would really help.
Rajesh
Rajesh, hi, can you provide some details on the "deployed in Production as a BAU deployment" part, describing how the propositions are deployed to production?
