Sakhatech Information Systems Pvt Ltd
Last activity: 31 Jul 2019 9:43 EDT
Pega API - calling assignments API for performing an assignment
HI,
I am in need of submitting an assignment through a thirdparty web application. I know that /assignments/{ID} is the API for submitting an assignment. But i dont find any documentation or sample to pass parameters to this rest API. The below screenshot shows the documentation for this API, but it is not clear what should be the values for these parameters.
Assume that i have an assignment with 3 fields in it.
- Name ( text )
- Age ( integer )
- Date Of Birth ( Date )
Please let me know how to call this API to perform the action through API
The ID parameter is the assignment's pzInsKey, like:
- ASSIGN-WORKLIST O59ALY-SCULPTURE-WORK I-21!SCULPT_FLOW
The actionID is the ID of the flow action, like:
- SubmitExpenseReport
The post body has the properties like this:
"content" : {
"Name" : "Ratheesh",
"Age" : 45,
"DOB" : "19730816",
"DateAndTimeOfBirth: "19730816T161555.716 GMT"
I hope this helps!
I have not received any reply to this neither i could solve this.
"content" : {
"Age" : 45,
"DOB" : "19730816",
I hope this helps!
Shivaprasad Katti Almir Gomes
Thanks Marik for your reply. I will try and let you know.
ING
How do I refer to more complex content like a table?
content: {
"myPageList" : [
"field1" : "row1value"
"field1" : "row2value"
Aditya Boggarapu
Cognizant Technology Solution
What's your question?
First of all, PUT /cases/{ID}?actionID=AddNote is the better choice for adding a note. Create a flow action AddNote for this purpose that takes transient fields Subject and Note set in the case body and creates a note out of them using the post-processing activity. The post-processing activity should create a page of class Data-WorkAttach-Note, and set pxAttachKey and pxAttachedBy in addition to the subject and note, then save it.
The JSON can be as you had it before, but you need to submit it with the right flow action that knows how to take those fields and put them into a note. I should add that attachment-style notes are deprecated nowadays in favor of pulse messages. We added POST /messages in recent versions.
Updated: 25 Jul 2019 10:02 EDT
Unfortunately I think we've reached the limit of what can be achieved through this medium. I will need to write a Community Article with step-by-step instructions to showcase this.
Hi Soumitrab, actually before I write an article, what version of Pega are you on? POST /messages has been in the product since 8.1 aka Pega Infinity. You should use POST /messages to create case notes.
7.3; I see. And why do you want to create an old attachment-style note over a pulse message?
Krishna Rajesh Karumuri Karumuri
