Virtusa
LK
Last activity: 29 Oct 2018 6:55 EDT
i want to add view button to repeating dynamic layout
Actually i have scenario to views values on repeating dynamic layout.i have use button and add local action to load the particular selected item. but it's not work properly .
Here Attached with screenshot
Coforge
Hi
Can you try removing Customer.Subscriptions. from using page field in the above configuration.
EvonSys India Pvt Ltd
Hi AnuradhaW,
Based on your attachment, you already viewing the selected item than what is the point of viewing in a separate window,
If I'm wrong, are u asking about how to add a new item to the repeating dynamic layout than in that case just in control action setting add DT or Activity to add a new item to item list(pagelist)
Rania Choura
Virtusa
LK
Actually, If the user click the View button, it will show whole information, Currently show important field only. if the user click view button, then it have to show more information than current screen
Hello Anuradha,
Are you trying to display extra information of the item in the modal dialog or overlay on click of the button?
Can you please share your configuration to show the details of the item on click of the button?
You can also have a look on Shopping Cart example in UI Gallery on the Repeating dynamic layouts usage.
Thanks!
Virtusa
LK
Here Attached with Configuration details
When you say that it is not working property, what exactly is the behavior that you are seeing?
Without seeing some more configuration details it's difficult to say what could be the problem, but something to consider is that there are 2 different "local action" actions (see hghlighted below). If you are using repeating data like a repeating dynamic layout then you need to use the version in the "List" category List / Open Local Action, so if you are curretly using the Launch / Local Action then you should try updating the configuration.
Virtusa
LK
Here Attached with Configuration Details
Coforge
Hi
Kensho Tsuchihashi Mukesh Agrawal Guangri Liang PRADEEP CHOWDARY PYDI John Sullivan and 16 More
Coforge
Hi
On click of the show button, Are you fetching the information from another data type of the selected item?
If it is from the repeating grid source, you would need to provide the screenshot of the configuration on the show button to understand the problem.
