Endeavour Energy
Last activity: 2 Sep 2018 2:09 EDT
To Show a column in report definition as link in pega 7
Iam looking for ways to show a column as link in report defintion in pega and on click of that link/ Open URL in Window actin should be triggered.
I have checked the control reporting_link but when placed it in column format of report definition. Unable to pass parameters to that control.
Sowjanya
***Updated by moderator: Lochan to update platform capability***
Can you try the following steps?
1. Configure a Repeat Grid layout in a section. Point the Repeat Grid to a Report Definition. and make the grid sourced dynamically.
2. Set one of the columns, using Link control, to open url in new tab/window.
Endeavour Energy
Hi Susan,
But users can modify filters to the report and also can export the results to excel. hence, looking for configuring it in report defintion only
CollabPartnerz
so can you try custom section option in report definition.
Endeavour Energy
Hi Gayatri,
I have tried to use custom section in report defintion. But on click of the link i need to show the attachments related to that work object in new scree/window.
I have used trigger action ( Open url in window) / Harness( New documet).
- While using Open url in window. when clciked on first time it is showing proper attachment. When clicked next time , it is not showing any attachments for the same row/different row.
- when used harness(with new document).Each time it is working fine.but it is retrieving all atttachments , i have checked in tracer as well(doUIActionHarness Pega OOTB activity is creating the new page: pyDisplayHarness and the value iam passing/or current page is not going).
Sowjanya
CollabPartnerz
Could you please share me the configuration info.
Endeavour Energy
Hi Gayatri,
Please find the configuration.
Sowjanya
CollabPartnerz
Can you try the same using section ?
CollabPartnerz
Below link might help you.
Endeavour Energy
which link?
