Health First
Last activity: 13 Aug 2018 5:16 EDT
Can I use IsInPageList function to compare a value to a data page?
The data page refers to a data type that holds a couple of records. What I want to do is compare a value against this data type and see if there's a match.
Thanks in advance!
Tata Consultancy Services
Hi Saml,
you can use D_DataPageTest.
@IsInPageList(Your Property value,"Your Property",D_DataPageTest).
This should resove your issue.
If your DataPage is of type list then you can use this function.
Health First
Hello Gayatri,
So when I use the datapage as the clipboard property, would this be the correct syntax to pass it: D_DataPageTest.pxResults ?
Hi Saml,
Yes,you can use this function as gayathri said if your DataPage is of type list.
Health First
Hi Vinay,
Okay so say the property 'DataPageProperty' to compare that's in the data page 'D_DataPageTestList' should the parameters be like this: @.IsInPageList("lookForThis", DataPageProperty, D_DataPageTestList) ?
Yes its correct.
lookForThis-- the value you are looking for
DataPageProperty--look at (Should be under pagelist definition class)
D_DataPageTestList-- Page List Ex:D_DataPageTestList.pxResults
Vinay Reddy
