Veteran Careers First
Last activity: 15 Jul 2018 3:36 EDT
substring/function to parse date
Looking for substring/function to parse date from file name.
I need the date in between the letter y and .xml
I only need the date, regardless of date format.
File Name examples:
- ABCtesty12018.xml####123456789
- ABCtesty012018.xml####123456789
- ABCtesty0012018.xml####12345678912
- ABCDtesty12018.xml####123456
- ABCDtesty012018.xml####12345678913
- ABCDtesty0012018.xml####12345678
Toyota Financial Services
To get the date as per the examples you provided. I understand below two functions will suffice your requirement.
indexof
substring
Something like below.
@substring(param.fileName, @indexOf(param.fileName, "ABCtesty"), @indexOf(param.fileName, ".xml"))
Sandeep P V
Harmen Denekamp Hector Melara
Awesome!
Lifesaver...
Thanks!
How would this look if I wanted to get everything before the letter t
You can also use below function for your requirement.
whatComesBeforeFirst(@String.whatComesAfterFirst("param.fileName",'y'),'.')
Vinay Reddy :)
LTI Mindtree
Thank you Vinay
We can use this function
Yeah Chaithanya
You have 2 t's in your string so you if you want everything before first t you can use "1st" function and if you want everything before last t you can use "2nd" function
ABC(t)es(t)y12018.xml####12345678
1.whatComesBeforeFirst(param.fileName,'t') -->ABC
2.whatComesBeforeLast(param.fileName,'t') -->ABCtes
Vinay Reddy :)
LTI Mindtree
Hi @HenryA80
Could you confirm your requirement, because I tried both the solutions (Vinay's and Sandeep's) in Pega 7.3.1.
Here is my observation, Vinay's soution is giving exact value (Date in between "y" and ".xml") what you want in your requirement and Sandeep's solution is giving exact file name excluding ".xml". Please find attachments.
If Sandeep's solution working as expected, then could you share how did you get the result.
Chaitanya,
They both worked!
I used in activity Pega 7.2.2
This was my final solution:
@substring(Param.FileName,@indexOf(Param.FileName,"y")+1,@indexOf(Param.FileName,"."))
I get the Date in between "y" and "."
I have both xml and csv, so instead of ".xml" I just used "."
Let me know if you have any other questions.
LTI Mindtree
Okay, then can you mark Vinay's post also "Correct Answer" so that it is helpful to other people and they can chose any one solution.
