Accenture
Last activity: 25 Jul 2018 16:39 EDT
Column alignment issue in progressive repeat grid
I am working on PEGA 7.1.8 . I have an issue in repeating grid when progressive is configured. When a repeat grid with progressive pagination contains more rows, the column alignment of records is perfectly fine with their column headers. If the number of rows is equal to less than the progressive rows, the column data with their header is badly misaligned. When i browsed through PDN, I found few posts with the same discussion and the resolution provided were two HFixes:
1. Apply HFix-33825
2. Apply HFix 36925.
Can anyone help me in finding the details of these Hfixes.
I checked the SR-C43430 which was associated to this. It seems that HFix-45463 resolved the issue. Yes, please an SR to get the hotfix.
HFix-33825: Changes has been made in " PZPEGA_UI_GRID" file. PRPC version is 7.2.1.
HFix 36925: Changes has been made in " PZPEGA_UI_GRID" file. PRPC version is 7.1.4.
These hotfixes seem to be applied in a similar use case you have. Do you have any specific query regarding these Hotfixes?
Accenture
Hi Rachit,
Thank you for the details. Query is exactly not on the hot fixes. I have an issue in the column alignment when repeating grid is made progressive. For that when i was browsing through PDN support, i got to know it is a product issue and got fixed via those two HFixes. Please find the links below:
https://community.pega.com/support/support-articles/column-alignment-issue-progressive-repeat-grid
https://community.pega.com/support/support-articles/headers-and-columns-repeating-layout-are-misaligned
So, i was looking for the hfix details. Ideally i need to fix the alignment issue. Appreciate your help on the same. I am working on PEGA 7.1.8 version.
You need to create SR to check if these hotfixes can be ported to 7.1.8
Arun
Cherif Haidra
Hi @ganginena,
Do let us know the SR# once created. We will continue to track it from this post.
Accenture
SR number is : SR-C43430
Thank you in advance
Thank you!
Texas Commission On Environmental Quality
Has this issue been resolved? I am also working on Pega 7.1.8 and facing the same problem.
Kindly let me know if I will have to raise separate support request.
