PEGA
PEGA
Posted: Jun 21, 2018
Last activity: Jul 17, 2018
Last activity: 17 Jul 2018 2:21 EDT
Configuring agent processing
Question 3
Show More
Question 3
Application requirements specify that an advanced agent runs on one node at a time. The cluster has three nodes. You set the Block execution within this time window for two hours for a cleaner agent that starts running at 10:00 on Node 1. Which outcome is correct?
The agent does not run on any node at 12:00.
The agent runs on node 2 at 11:30.
The agent runs on node 3 at 11:30.
The agent does not run on any other node at 11:00.
Correct!
After the agent starts running at 10:00, it is blocked from running on any other node until 12:00.
Show Less
