Bits In Glass
Last activity: 25 Sep 2018 6:52 EDT
Issue with Exception handling in Obj-open/ open-by-handle method
I am trying the column population for an exposed column, so used an Activity with obj-open, though it works for the most work objects, for some of the instances it is failing with WrongModeException. Is it possible to have a java code instead of obj-open/open-by-handle methods which open the work object and catches any exception.
Please provide the java code which can do this.
Aaseya IT Services Pvt Ltd
SA
Check below link.
https://collaborate.pega.com/question/how-access-case-data-clipboard-external-java-code
Bits In Glass
Hi hitlx,
I dont have my data onto the clipboard yet, if i do then why would i ask for a java code.
The intention here is to obj-open a database instance and if failed to error handle.
Areantans
looks like mismatch the property type. can you attached the trace as well
Bits In Glass
Attached the TracerEvents
You can use the transition of the activity step to handle exceptions. See attached screen shot for configuration.
To do this in java,
try{
ClipboarPage cp= tools.getDatabase().open("inskey",false);
}catch(Exception e){
Refer engine api for more overridden methods of Open.
Bits In Glass
The transition would not work as the exception is java...
When i try the java code, i am unable to see the instance opening in cp. I added a new step below java with primary page as cp.
Does the java code work only on top level pages and not on iterations (pxResults) ?
In java code did you get any exception, is it coming to catch block?
You cannot directly refer cp as step page, as that clipboard page is created within that java step context.
Exception thrown by obj-open-by-handle should be caught. Since we have given 'on exception jump to later step - ERR' in the transition.
CollabPartnerz
Please use StepStatusFail When condtion for both methods of obj-open and obj-open-by-handle to jump it.
Madhusudan Sharma
Bits In Glass
Nope, if transitions does work then there is no need for java code, isn't it? The Activity that i have should run even on the work objects with wrong or un-built structures.
Krzysztof Wiśniewski
Bits In Glass
Any update on this?
Tata Consultancy Services
Bits In Glass
I happen to see another case similar to the one mentioned, when i do a obj-open-by-handle or obj-open, the Tracer doesnot show the steps of obj-open end step, rather it displays an Activity End and Logs an error as PRRunTimeException.
