Ability to format column justification in a PDF export generated from a report
I am looking for a way to define data justification (right or left) in the columns of a PDF export, is this possible to do?
***Edited by Moderator to add SR Details***
Hi Sean,
1. For The RD which is to be exported, In the DataAccess tab check "Ignore application Skin when exporting to PDF" checkbox.
2.Apply your custom css in pyReport_ExportToPdfStyles (This style rule will be picked up when you check the RD rule dataaccess "Ignore application Skin when exporting to PDF")
3.For right Justification of columns I have overridden the fontFamily class in the css file.
I have attached the screenshots for your reference. Hope it helps .
You can also refer this article for more info
https://community.pega.com/support/support-articles/report-cell-borders-are-not-rendered-exported-pdf
