ING Belgium SA NV
ING Belgium SA NV
BE
ING Belgium SA NV
Posted: May 7, 2018
Last activity: Aug 26, 2020
Last activity: 26 Aug 2020 8:41 EDT
Upgrade.bat scripts Could not reserve enough space for object heap
While running upgrade scripts in our dev environment, we are often facing “Could not reserve enough heap space for 1310720 KB object heap”
We made sure of below points,
- System uses 64 bit JDK
- Set the environment variables(_JAVA_OPTIONS as system variable for –xms1024m). It is not allowing more than that.
- Client machine is 64-bit system having 15.7 GB free memory.
- We could see the CPU memory still 5.67 GB(from task manager)
- We cleared temp folder too
PFA, logs for the same.
Kindly advise if we are missing something here.
