Quarkxpress Publishing R d PVT Ltd
Posted: Apr 18, 2018
Last activity: Apr 18, 2018
Last activity: 18 Apr 2018 1:48 EDT
Getting error performing Exercise: Routing work to case participants > Verify your work
I am going through CSA Essentials.
I am getting the below error in chapter : Assigning Work
Below is the error details:
Work Object Not Found
Application HRApps
Message Unable to open an instance using the given inputs
The error appears after i deleted an Expense Report Case while performing an exercise of topic: Routing work to case participants > Verify your work
I have attached the screenshot for same.
Advance Thanks,
RCJ
***Moderator Edit: Vidyaranjan | Moved from PSC to Academy***
