Accenture
Last activity: 2 May 2018 7:01 EDT
Issue with import command while using encrypted password in prpcutils.properties
I'm facing the issue while using the import command to deploy the package, here i need to hide the db password in utils.properties file so I did the following steps to achieve the password encryption:
1. To generate the keyring I updated the prconfig file and prbootsrap file with database details and can able to generate the keyring for prconfig file. I used the following command to generate the keyring file:
Command:
Command:
java -Xms128m -Xmx256m -classpath .:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/prbootstrap.jar:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/prbootstrap-api.jar:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/jsr94-1.0.jar:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/prbootstrap-api.jar:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/prdbcp.jar:/apps/Oracle/Middleware/wlserver_12.1/server/lib/ojdbc6.jar -Dpegarules.logging.configuration=./config/prlogging.xml -Dcom.pega.pegarules.bootstrap.properties.url=./config/prbootstrap.properties -Dpegarules.config=./config/prconfig.xml -Dcom.pega.pegarules.bootstrap.ignorejndi=true com.pega.pegarules.pub.PegaRULES com.pega.pegarules.exec.internal.util.crypto.KeyringImpl ./config/pegarules.keyring ./config/prconfig.xml "/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib"
2. I ran the PassGen command to get the encrypted password for prboostrap file, before running this command I used clear text password in the prbootsrap.properties file. After getting the encrypted password I replaced the password field with the encrypted one. I used the following command to generate the keyring file :
Command:
java -classpath :/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/prbootstrap.jar:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/prbootstrap-api.jar:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/jsr94-1.0.jar:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/prbootstrap-api.jar:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/lib/prdbcp.jar:/apps/Oracle/Middleware/wlserver_12.1/server/lib/ojdbc6.jar com.pega.pegarules.pub.PassGen welcome1
-The following are the changes done after having the keyring and encrypted password
For prbootsrap.properties file:
- I replaced the password field with the encrypted password field which got generated from PassGen
For prconfig.xml file:
- I added the following step and removed the 2 steps which has password details:
<env name="initialization/settingsource" value="merged" />
For prpcutils.properties file:
- I added the following paths and left the pega.jdbc.password= as empty
pegarules.config=/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/config/prconfig.xml
prbootstrap.config=/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/config/prbootstrap.properties
For prpcutils.xml file:
- Here i added a new path element location as follows around 242 line:
<pathelement location="/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/config/"/>
- And I commented out the pega test connection and modified "Processing Configuration Files" task around line 421 to remove the depends='_findSystemName"
- Exactly at the 651 step i'm getting the decode error, below is the 651 step in the prpcutils.xml file:
<java classname="com.pega.pegarules.pub.PegaRULES" failonerror="true" fork="true" dir="${load.temp.dir}">
<classpath refid="prpc.base.path"/>
<!-- <jvmarg value="-Dpegarules.keyring="/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/config/pegarules.keyring"/> -->
<jvmarg value="${jvm.arg.mem.max}"/>
<jvmarg value="${jvm.arg.mem.maxpermsize}"/>
<sysproperty key="com.pega.pegarules.bootstrap.properties.url" value="file:///${prbootstrap.config}" />
<sysproperty key="pegarules.config" value="${pegarules.config}" />
<arg value="com.pega.pegarules.deploy.external.util.ImportUtility" />
<arg line="-a "${import.archive.absolute.path}""/>
<arg line="${arg.line}"/>
</java>
Following is the error i'm facing now while using the import command :
Error:
[java] Current "user.dir" (default directory) is: /apps/Oracle/Middleware/user_projects/domains/PegaDomain/pr_temp/PegaInstallTemp-11-April-2018-17.26.26/load
[java] Located PegaRULES logging configuration: file:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/pr_temp/PegaInstallTemp-11-April-2018-17.26.26/load/WEB-INF/classes/prlogging.xml
[java] Found spec for PegaRULES (V5.x) configuration using System property: /apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/config/prconfig.xml
[java] Located PegaRULES (V5.x) configuration: file:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/config/prconfig.xml
[java] Apr 11, 2018 5:26:38 PM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
[java] 19830421: Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 2018-04-11 17:26:38,775 [ main] [ ] [ ] ( basic.config.SettingsImpl) INFO - prconfig.xml merged with prconfig entries in Data-Admin-System-Settings
[java] 2018-04-11 17:26:39,018 [ main] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - Using Hybrid Virtual Rules Table implementation
[java] 2018-04-11 17:26:39,018 [ main] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - VTable dispatches rules for 7 Aspects: 'Validate, Model, Action, Input, When, Alias, Collection'.
[java] 2018-04-11 17:26:39,019 [ main] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - ABA[AC] dispatches rules for 1 Aspect: 'Stream'.
[java] 2018-04-11 17:26:39,021 [ main] [ ] [ ] ( priv.context.JNDIEnvironment) INFO - Enterprise-tier default Engine bean name is EngineBMT
[java] 2018-04-11 17:26:39,025 [ main] [ ] [ ] (r.context.EtierEnvironmentImpl) WARN - Enterprise tier has no local JNDI context
[java] reason: Need to specify class name in environment or system property, or as an applet parameter, or in an application resource file: java.naming.factory.initial
[java] 2018-04-11 17:26:39,233 [ main] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - invokeDynamic instrumentation for inlining is enabled
[java] 2018-04-11 17:26:39,233 [ main] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - Assembly Version: -1551638810
[java] 2018-04-11 17:26:39,650 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - PegaRULES Embedded Edition 7.10 (ML8)
[java] 2018-04-11 17:26:39,650 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - coreAssemblyCached_718_675: 2015-05-20 18.49 EDT
[java] 2018-04-11 17:26:39,650 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - Now starting the PegaRULES Embedded Environment...
[java] Found spec for KeyringImpl keyring using System property: /apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/config/pegarules.keyring
[java] Located KeyringImpl keyring: file:/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/Additional_Products/BIX/config/pegarules.keyring
[java] 2018-04-11 17:26:39,713 [ main] [ ] [ ] (cess.DatabaseConfigurationImpl) ERROR - The properties file specified for database pegadata does not exist
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Base database information:
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegadata
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JDBC URL
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - JDBC URL: jdbc:oracle:thin:@t115plohtb01:1521:pegadevb
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema: PEGA3
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (cess.DatabaseConfigurationImpl) ERROR - The properties file specified for database pegarules does not exist
[java] 2018-04-11 17:26:39,717 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegarules
[java] 2018-04-11 17:26:39,718 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JDBC URL
[java] 2018-04-11 17:26:39,718 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - JDBC URL: jdbc:oracle:thin:@t115plohtb01:1521:pegadevb
[java] 2018-04-11 17:26:39,718 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
[java] 2018-04-11 17:26:39,718 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
[java] 2018-04-11 17:26:39,718 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
[java] 2018-04-11 17:26:39,718 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema: PEGA7RULES
[java] 2018-04-11 17:26:39,811 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) ERROR - Exception during startup processing
[java] com.pega.pegarules.pub.PRRuntimeException: Error determining the mode of PRPC install from database.
[java] at com.pega.pegarules.data.internal.PRDataProviderImpl.isMultiTenantEnvironment(PRDataProviderImpl.java:1135)
[java] at com.pega.pegarules.deploy.internal.archive.ParUtilsImpl.setStageDirectory(ParUtilsImpl.java:219)
[java] at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:511)
[java] at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
[java] at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
[java] at com.pega.pegarules.session.internal.mgmt.EngineImpl.startEngineImpl(EngineImpl.java:240)
[java] at com.pega.pegarules.session.internal.mgmt.EngineImpl.startEngine(EngineImpl.java:119)
[java] at com.pega.pegarules.session.internal.mgmt.EngineImpl.startEngine(EngineImpl.java:112)
[java] at com.pega.pegarules.deploy.external.util.ImportUtility.main(ImportUtility.java:182)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:606)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] Caused by: com.pega.pegarules.pub.database.DatabaseException: Database-General Problem encountered when getting connection for database pegarules 1017 72000 ORA-01017: invalid username/password; logon denied
[java]
[java] From: (unknown)
[java] Caused by SQL Problems.
[java] Problem #1, SQLState 72000, Error code 1017: java.sql.SQLException: ORA-01017: invalid username/password; logon denied
[java]
[java] at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:262)
[java] at com.pega.pegarules.data.internal.access.ConnectionManagerImpl.getConnectionFromDatabaseName(ConnectionManagerImpl.java:856)
[java] at com.pega.pegarules.data.internal.access.ConnectionManagerImpl.getConnection(ConnectionManagerImpl.java:1187)
[java] at com.pega.pegarules.data.internal.access.ConnectionManagerImpl.getConnection(ConnectionManagerImpl.java:1129)
[java] at com.pega.pegarules.data.internal.access.ConnectionManagerImpl.getConnection(ConnectionManagerImpl.java:343)
[java] at com.pega.pegarules.data.internal.PRDataProviderImpl.isMultiTenantEnvironment(PRDataProviderImpl.java:1125)
[java] ... 17 more
[java] Caused by: java.sql.SQLException: ORA-01017: invalid username/password; logon denied
[java]
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:445)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:389)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:382)
[java] at oracle.jdbc.driver.T4CTTIfun.processError(T4CTTIfun.java:600)
[java] at oracle.jdbc.driver.T4CTTIoauthenticate.processError(T4CTTIoauthenticate.java:445)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:450)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
[java] at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:380)
[java] at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:760)
[java] at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:401)
[java] at oracle.jdbc.driver.PhysicalConnection.<init>(PhysicalConnection.java:546)
[java] at oracle.jdbc.driver.T4CConnection.<init>(T4CConnection.java:236)
[java] at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:32)
[java] at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:521)
[java] at java.sql.DriverManager.getConnection(DriverManager.java:571)
[java] at java.sql.DriverManager.getConnection(DriverManager.java:215)
[java] at com.pega.pegarules.data.internal.access.ConnectionManagerImpl.getConnectionFromDatabaseName(ConnectionManagerImpl.java:769)
[java] ... 21 more
[java] 2018-04-11 17:26:39,821 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - Embedded Environment initialization failed.
[java] 2018-04-11 17:26:39,821 [ main] [ ] [ ] ( external.util.ImportUtility) ERROR - Unable to Start PegaRULES:
[java] 2018-04-11 17:26:39,822 [ main] [ ] [ ] ( external.util.ImportUtility) ERROR - A problem occurred during import.
[java] com.pega.pegarules.pub.PRException: Unable to start engine.
[java] at com.pega.pegarules.deploy.external.util.ImportUtility.main(ImportUtility.java:191)
[java] Apr 11, 2018 5:26:39 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.PRException: A problem occurred
[java] at com.pega.pegarules.deploy.external.util.ImportUtility.main(ImportUtility.java:249)
[java] Caused by: com.pega.pegarules.pub.PRException: Unable to start engine.
[java] ... 9 more
[java]
[java] Apr 11, 2018 5:26:39 PM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
[java] ... 9 more
[java]
[java] Exception in thread "main" java.lang.RuntimeException: Problem during method invocation (main)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:278)
[java] Caused by: com.pega.pegarules.pub.PRException: A problem occurred
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
[java]
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
[java] ... 1 more
[java]
[java] at com.pega.pegarules.deploy.external.util.ImportUtility.main(ImportUtility.java:191) at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
[java] ... 9 more
[java]
BUILD FAILED
/apps/Oracle/Middleware/user_projects/domains/PegaDomain/Pega_DevOps/PRPC_Utility/scripts/utils/prpcUtilsTarget_DEV.xml:651: Java returned: 1
Total time: 14 seconds
Ant Process returned a non 0 value
Can anyone suggest the resolution for this issue.
V Vishal
