Stage:This field may not be blank.
When I submit a form to create a support request or SR generate an message error: " Stage:This field may not be blank".
The field not exist in this form.
Not sure why exactly you are not able to see the field value or why the error message is coming.
Maybe your account executive can help in this case.
please share a screenshot of the screen so that we can help further, just try filling it again :)
After cross checking based on your registration details came to know that you had not been linked to your account by your Admin, so kindly follow the below steps:
If you still can't raise the SR, then kindly raise the issue in your MSP with the necessary screenshots.
Regards
Mahesh
