Does Global Resource Settings support parameterized datapage ?
Getting the following exception when a parameterized datapage is used for grs in a parse delimited rule
Try using this syntax,
<YourDataPgName>[<ParamName>:"<ParamValue>"].<PropertyReference>
Hope it helps, kindly notify if it does for broader audience.
Asif
Still the same
I think it may be an expected behaviour as it needs retrieval of data in data-page with parameter thus one page. And maintenance of this data as the global resource is opposite to the purpose of Global Resource Settings, though not sure.
Have you tried referring it any other rule? Like as global variable with the above syntax. Or try printing or setting value in a property whether it's able to retrieve?
