Dell
BR
Last activity: 22 Feb 2018 7:22 EST
Image not rendering properly on logout
I'm trying to present a logoff screen with the same image I'm showing in the login screen.
Once the user session is finished and redirected to logout screen the image is not loading. This issue is happening only when the user is authenticated via SSO.
If I use a external source to load the image it is working properly.
The Log off redirection option in the application rule is set to "Redirect To Login Screen".
In the development environment without SSL(https) the same code is working as expected but in the pre-prod environment with SSL this issue is happening.
Attached is the screen shots of the expected behavior, the current behavior and the HTML rule.
