de Volksbank
Last activity: 3 Mar 2019 22:06 EST
how to convert .log file to .json.log - We have to use for ELK
We have recently configured the ELK in dev region and we have. For Kibana we have to pass .json.log as input but we have only .log files.
How to generate the .json.log file from .log file.
This is what we followed for setting up ELK:
Regards
Gouri Shankar K
JPMorgan Chase & Company
de Volksbank
Hi - i know how to configure the appender, i have already posted the configuration link, .json.log is generating properly.
My question is how to convert the .log file to .json.log. (This is for existing .log files i want to analyse through kibana.)
We are on pega 7.3.0 so we have done it in prlog4j2.xml (prloggig.xml is not supported for this version)
Regards
Gouri Shankar K
Trivento
Hello GOURI_SHANKAR_K,
Would you like to share your prlog4j2 xml configuration please?
I'm trying to do the same but haven't found any good example or setup yet.
Thanks in advance,
Machiel
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
de Volksbank
Waiting for solutions..
de Volksbank
There isn't anything in Pega out of the box that can do this, you'll have to see what you can find online for this. For example: https://stackoverflow.com/questions/21477997/converting-existing-log-files-to-json-format-for-analysis-purposes
The comments here suggest that a script could be created to do this or a logstash filter.
