LTIMindtree
Does Openspan Winhllapi text adapter interrogation allow keyboard keys like Pause break
I'm working on Interrogating a IBM Pcomm Winhllapi Text adapter to invoke a Mainframe application (MyExtra Enterprise). My Text Adapter is not allowing Pause Break key. Im Mainframe , on click on Pause Break, it should move to next screen. Any suggestions
Standard Chartered Global Business Services
Use 'SendKeyToHost' method with parameter 'Clear' on the emulator. The 'Clear' parameter behaves the way as Pause Break functionality.
LTIMindtree
Thank you Murugan for the response. I'm able to move further in Automation, but facing issue while interrogating the screens in Text Adapter. Unable to capture next screens even after pressing Pause/Break button.
Soujanyaal, I'm not getting the issue. Do you mean the Mainframe window is not responding to Pause/Break or the Text Adapter not reflecting the next screen even after the Mainframe screen has been navigated?
LTIMindtree
While doing the interrogation, Text designer screen is not moving forward. So i'm unable to capture next screens
if you stop interrogation and restart interrogation while you're on that new screen - does it still not show?
Does the session set on your Text Adapter match with the Mainframe window session?
LTIMindtree
Yes. And also i'm able to capture first four screens. Issue is occurring in Fifth screen, where pause/break button is not being recognized by Adapter.
It is difficult to comment without seeing the issue. Suggest to raise a ticket/SR so that Pega support could check this issue, if still not resolved.
