Newyorklife
Last activity: 30 Jan 2018 16:44 EST
Popup error when upgrade pega6.2SPS2 single schema to 7.1.8 split scheme
We are in the process of upgrading our system from pega6.2SP2 to 7.18, we are using IUA tool.
We are getting error and terminate upgrade tool. find attached the error log.
[java] 2018-01-24 12:23:26,084 [ L184042] [ ] [ ] ( etier.impl.EngineStartup) ERROR - PegaRULES initialization failed. Server: L184042
[java] com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
Caused by: com.pega.pegarules.pub.context.PRSecurityException: Unable to construct authorization core due to authorization failure
[java] Caused by: com.pega.pegarules.pub.context.InvalidConfigurationException: Data-Admin-Requestor instance "${current.system.name}!BATCH" not found
[java] From: (BAE39DDB229197C0699BEB52E836DC137)
Our configuration in IUA tool
pega.jdbc.driver.jar=C:\NYL\ProcessGateway\Pega 7.1.8 Binaries\db2jcc.jar
pega.jdbc.driver.class=com.ibm.db2.jcc.DB2Driver
pega.database.type=udb
pega.jdbc.url=jdbc:db2://aixqadb1:60052/pegaqap2:fullyMaterializeLobData=true;fullyMaterializeInputStreams=true;progressiveStreaming=2;useJDBC4ColumnNameAndLabelSemantics=2;
pega.jdbc.username=db2qapg2
pega.jdbc.password=******
rules.schema.name=pegadpg (existing single schema)
data.schema.name=pegarpg (New schema)
user.temp.dir=
pega.zos.properties=
run.assembler=
import.assembled.classes=true
system.name=pega
production.level=2
multitenant.system=false
update.existing.applications=false
import.codeset.name=Customer
import.codeset.version=06-01-01
