EY
BR
Last activity: 3 Jan 2018 9:56 EST
Populating a listbox from sql
Hi Pega community!
Im having some problems on how to populate a listbox from a sql table, using a Pega Form.
Edit: Just adding some info, i cant "add item" to these listboxes, as you can see i dont even have this method.
So in this form, we have two lists. The first one i will populate itens from SQL table, and the second one will only receive data from the first list.
Basically I have two problems, first is populating a listbox from SQL Server and move itens between two different list boxes.
Thanks for the help!
***Edited by Moderator to update categories***
