![](https://accounts.pega.com/sites/default/files/pega-user-image/458/REG-457943.png?source=PUMINIT)
Capgemini
ES
Last activity: 24 May 2018 9:37 EDT
Pega academy error
Im trying to do the Exercise: Automatically updating the total cost of benefits
But when i try to save the expression for the Total Benefit Cost I have this error:
***Updated by moderator: Lochan to move post from PSC to Pega Academy***
Capgemini
ES
JPMorgan Chase & Company
Please check the property EmployeeCost is present in TGB-HRApps-DATA-HRPlan class ?. Showing property undefined.
CGI Group Inc
I am also facing the same issues. Can you please share how to resolve this error?
EPAM Systems, Inc.
ES
Hi Daniel,
Thanks for posting on PSC.
Just to confirm, open "App Explorer" from right side pane. Under TGB-HRApps-Data-HRPlan class, verify that you have "EmployeeCost" property defined. If not, please create one.
This could be possible, in case you have skipped the previous exercises.
Hope it rectifies your use-case, kindly notify if it does.
Asif
Capgemini
ES
The property EmployeeCost is not defined, but it is external maped:
Accenture
SG
I am having the same issues. May I know what is the resolution?
SiXworks Limited
The property must exist (in your case, be created). The External Mapping tab on a Class rule allows you to map an existing property to a column with a different name on the associated database table.
Solution is to create the EmployeeCost property, as Asif suggested.
Ruletek LLC
I am having this issue too. The EmployeeCost property is not defined, and if I try to create it I get an error "No unlocked RuleSets/Versions found that are valid for this record."
