Fifth Third Bank Bank
Last activity: 26 Dec 2017 14:35 EST
How to access .NET class library Properties.Settings from Pega/OpenSpan automation
Can a Pega/OpenSpan automation project use config file settings to change values used in "Properties.Settings" of a .NET DLL? I am trying to something similar to how one might set up a Visual Studio solution.
For example, a VS solution might have two projects: a web application project and a class library project. The class library project might have property settings, which enable type-bound references like "MyProjectNamespace.Properties.Settings.Default.MySettingName". Using Properties.Settings would generate entries in the app.config file something like that seen below. Then in the consuming web application project, the configSections and applicationSettings configuration elements would be copied/pasted into the web.config file.
<configuration>
<configSections>
<sectionGroup name="applicationSettings" type="System.Configuration.ApplicationSettingsGroup, ... etc..." >
<section name="MyProjectNamespace.Properties.Settings" type="System.Configuration.ClientSettingsSection, ... etc..." />
</sectionGroup>
</configSections>
<applicationSettings>
<MyProjectNamespace.Properties.Settings>
<setting name="MySettingName" serializeAs="String">
<value>SomeValue</value>
</setting>
<!-- ... etc ... -->
</MyProjectNamespace.Properties.Settings>
</applicationSettings>
</configuration>
My question is if something like this is possible with Pega/OpenSpan? For example, can the RuntimeConfig.xml file be modified in a way, so that the DLL from the .NET class library project would pick up new settings (e.g. - prod vs. dev)? Or, can an existing app.config be deployed in a way to be picked up by the solution? If so, please describe the correct procedure, or a viable work-around. I have tried adding the above settings (leads to error), and I have tried putting an app.config file in various locations including the location of the Pega project, and the Pega installation folder.
Thanks!
