Virtusa Corporation
Last activity: 19 Dec 2017 5:32 EST
Agile Studio (7.3) integration with TMF (Test Management Framework)
I'm trying to use TMF options in Agile Studio 7.3. However there is no option for me to work with the test related options in agile studio. Is there any set up/configurations which i have to take place in order to see these options (such as Test Case, Test Run, test Suite, etc.)?
Hello Shehan, thank you for your query. In 7.3 the TMF was removed but due to few requests, we are going to add it back. For time being, we are going provide a hotfix to get the TMF back.
Virtusa Corporation
Thanks Vijay for the input. Is the hotfix available currently? If not when can we expect it?
It is available, please contact our GCS team they can help
Virtusa Corporation
Would you be able to provide the hotfix number? So that it is easier to get the communication going with them. Again thanks for the prompt responses.
Knowledge Expert
DE
i was also interested to upgrade to Pega Agile Studio 7.3. But since you said, that TMF has been removed, i am no more sure.
Can you please communicate the hotfix ID and which release will contain PMF again and when it will be released.
Herve
Updated: 14 Dec 2017 5:54 EST
Here are the hot fixes for 7.3 and 7.31 Agile Studio versions:
HFix-39439 [For 7.31 Version]
HFix-39439 [For 7.3 Version]
Hope this helps
Estes Express Lines
Yes it does. I have opened an SR for the hotfix. Thanks!
Estes Express Lines
Hi Vijay,
One more question. This hotfix should bring the TMF options (Test Case, Test Suite, Test Run) under 'Create (+)' menu right? Or is there a different place to find them?
Thanks!
Yes, In hotfix we have enabled Test Case, Test Suite and Test Run under Create (+) menu.
Regards.
Krati
Corrected the HFIX labels :-
HFIX73-39439 [For Agile studio 7.3 Version]
HFIX731-39439 [For Agile studio 7.3.1 Version]
