Pega 7.2.0 Steps to Configure Elastic Search
I am trying to understand how to configure the elastic search for an end user portal. The aim is to allow a full text search and then to display this in a grid on the UI much in the way the rules search works in the developer studio.
The steps I have followed so far are...
1. Enabled the dynamic system setting indexing/useDataInstances
2. Created an instance of Data-CustomProperties-Search specifying some embedded properties. These are to be shown in the search results.
3. Created a report definition in the framework class of the work items I am searching for. This is configured to report on descendant classes. The columns defined in the report definition include some of the properties in the instance of Data-CustomProperties-Search that I created.
4. Create an activity to call pxRetrieveSearchData passing into that the search string and the report definition class and name.
5. I have reindexed the work index via the search landing page.
6. I have checked that FTSIncrementalIndexer is running.
The search is not working so what am I missing? I can see the activtiy running and if a basic search string is entered such as "a" then it brings back some results, however if some data is entered that I know exists on a case then nothing is returned.
The assumptions I had in terms of operation of the elastic search were:
1. All the data in the work item is stored in the index.
2. The report definition is to specifiy how the results should be returned.
3. The intances of Data-CustomProperties-Search are to allow those properties to be referenced in the report definition and included in the results of the search of the index.
4. I have rebuilt the Data- and Work- indexes however I assume that for embedded page properties in a work class then the Work- index is sufficient for this.
5. Instances of Data-CustomProperties-Search will be inherited. So I can define these in the Framework layer class and it is not needed to create the same in the implementaton classes.
