Capgemini
FR
Last activity: 5 Feb 2018 15:29 EST
Display portal unauthenticated user
I have seen many posts about this issue, but no clear resolution. I am trying again to launch a discussion on this as my issue is not about customisation of login page, which is pretty straight forward, but making a whole part of the application available to guest users.
I tried to set an access group with all required roles in requestor type but it doesn't work. Activity set in requestor type is always redirecting to authentication. I tried to use Data-Portal.ShowDesktop activity but then it displays I have no permission to load this portal, I don't understand why.
There are exemple of this functionnality in self service protal of pega, but in documentation what is said is to set CPMWSUser access group in requestor type, nothing more while it is clearly not enough, still going to authentication rule.
thanks for your help guys !
