Bank Sinarmas
ID
Last activity: 17 Nov 2017 5:16 EST
unable to deploy prweb.war
Please help when deploy prweb.war get this error :
15:10:13,865 ERROR [org.jboss.as.controller.management-operation] (HttpManagementService-threads - 1) JBAS014612: Operation ("add") failed - address: ([("deployment" => "prweb.war")]) - failure description: {"JBAS014771: Services with missing/unavailable dependencies" => [
"jboss.naming.context.java.module.prweb.prweb.env.jdbc.AdminPegaRULES is missing [jboss.naming.context.java.jdbc.PegaRULES]",
"jboss.naming.context.java.module.prweb.prweb.env.jdbc.PegaRULES is missing [jboss.naming.context.java.jdbc.PegaRULES]"
15:10:13,868 ERROR [org.jboss.as.server] (HttpManagementService-threads - 1) JBAS015870: Deploy of deployment "prweb.war" was rolled back with the following failure message:
I already search on pdn but cant find the solution.
version of Jboss eap 6.4 linux and oracle 12c
Siva Jyothi PamiReddy
Bank Sinarmas
ID
Hi Mahesh,
Thanks for the reply, already add the binding but still get same error. i'm using pega platform 7.1.9.
i attached the error log.
Hi Julian,
Could you please share the standalone-full.xml file and also let me know the below information:
- Split/Single schema?
- Dual/Single user configuration?
- Had you upgraded the environment or its a fresh installation?
- Any reason behind deploying the war file instead of ear file in the JBOSS application server?
Kindly let me know the above information for further analysis.
Regards
Mahesh
Hi julian,
I guess I have faced thi in past :)
From PRPC7.2.2 onwards I believe we need to creade another Data Source with name AdminPegaRULES
You can add another Datasource with name AdminPegaRules similar to pegaRules and it should work.
Ujjwal
Bank Sinarmas
ID
Hi Ujjwal,
Try that but still get same error. already create another datasource AdminPegaRULES.
Hi Julian,
Login to Jboss Admin console and check for data source if AdminPegaRules is present.
Please find working Standalone-full.xml below.
You can probably customize and use it straightaway.
Ujjwal
Hi Julian,
Ujjwal
<?xml version='1.0' encoding='UTF-8'?>
<server xmlns="urn:jboss:domain:1.7">
<extensions>
<extension module="org.jboss.as.clustering.infinispan"/>
<extension module="org.jboss.as.cmp"/>
<extension module="org.jboss.as.connector"/>
<extension module="org.jboss.as.deployment-scanner"/>
<extension module="org.jboss.as.ee"/>
<extension module="org.jboss.as.ejb3"/>
<extension module="org.jboss.as.jacorb"/>
<extension module="org.jboss.as.jaxr"/>
<extension module="org.jboss.as.jaxrs"/>
<extension module="org.jboss.as.jdr"/>
<extension module="org.jboss.as.jmx"/>
<extension module="org.jboss.as.jpa"/>
<extension module="org.jboss.as.jsf"/>
<extension module="org.jboss.as.jsr77"/>
<extension module="org.jboss.as.logging"/>
<extension module="org.jboss.as.mail"/>
<extension module="org.jboss.as.messaging"/>
<extension module="org.jboss.as.naming"/>
<extension module="org.jboss.as.pojo"/>
<extension module="org.jboss.as.remoting"/>
<extension module="org.jboss.as.sar"/>
<extension module="org.jboss.as.security"/>
<extension module="org.jboss.as.threads"/>
<extension module="org.jboss.as.transactions"/>
<extension module="org.jboss.as.web"/>
<extension module="org.jboss.as.webservices"/>
<extension module="org.jboss.as.weld"/>
</extensions>
<management>
<security-realms>
<security-realm name="ManagementRealm">
<authentication>
<local default-user="$local" skip-group-loading="true"/>
<properties path="mgmt-users.properties" relative-to="jboss.server.config.dir"/>
</authentication>
<authorization map-groups-to-roles="false">
<properties path="mgmt-groups.properties" relative-to="jboss.server.config.dir"/>
</authorization>
</security-realm>
<security-realm name="ApplicationRealm">
<authentication>
<local default-user="$local" allowed-users="*" skip-group-loading="true"/>
<properties path="application-users.properties" relative-to="jboss.server.config.dir"/>
</authentication>
<authorization>
<properties path="application-roles.properties" relative-to="jboss.server.config.dir"/>
</authorization>
</security-realm>
</security-realms>
<audit-log>
<formatters>
<json-formatter name="json-formatter"/>
</formatters>
<handlers>
<file-handler name="file" formatter="json-formatter" path="audit-log.log" relative-to="jboss.server.data.dir"/>
</handlers>
<logger log-boot="true" log-read-only="false" enabled="false">
<handlers>
<handler name="file"/>
</handlers>
</logger>
</audit-log>
<management-interfaces>
<native-interface security-realm="ManagementRealm">
<socket-binding native="management-native"/>
</native-interface>
<http-interface security-realm="ManagementRealm">
<socket-binding http="management-http"/>
</http-interface>
</management-interfaces>
<access-control provider="simple">
<role-mapping>
<role name="SuperUser">
<include>
<user name="$local"/>
</include>
</role>
</role-mapping>
</access-control>
</management>
<profile>
<subsystem xmlns="urn:jboss:domain:logging:1.5">
<console-handler name="CONSOLE">
<level name="INFO"/>
<formatter>
<named-formatter name="COLOR-PATTERN"/>
</formatter>
</console-handler>
<periodic-rotating-file-handler name="FILE" autoflush="true">
<formatter>
<named-formatter name="PATTERN"/>
</formatter>
<file relative-to="jboss.server.log.dir" path="server.log"/>
<suffix value=".yyyy-MM-dd"/>
<append value="true"/>
</periodic-rotating-file-handler>
<logger category="com.arjuna">
<level name="WARN"/>
</logger>
<logger category="org.apache.tomcat.util.modeler">
</logger>
<logger category="org.jboss.as.config">
<level name="DEBUG"/>
</logger>
<logger category="sun.rmi">
</logger>
<logger category="jacorb">
</logger>
<logger category="jacorb.config">
<level name="ERROR"/>
</logger>
<root-logger>
<handlers>
<handler name="CONSOLE"/>
<handler name="FILE"/>
</handlers>
</root-logger>
<formatter name="PATTERN">
<pattern-formatter pattern="%d{HH:mm:ss,SSS} %-5p [%c] (%t) %s%E%n"/>
</formatter>
<formatter name="COLOR-PATTERN">
<pattern-formatter pattern="%K{level}%d{HH:mm:ss,SSS} %-5p [%c] (%t) %s%E%n"/>
</formatter>
</subsystem>
<subsystem xmlns="urn:jboss:domain:cmp:1.1"/>
<subsystem xmlns="urn:jboss:domain:datasources:1.2">
<datasources>
<datasource jndi-name="java:jboss/datasources/ExampleDS" pool-name="ExampleDS" enabled="true" use-java-context="true">
<connection-url>jdbc:h2:mem:test;DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE</connection-url>
<driver>h2</driver>
<security>
<user-name>sa</user-name>
<password>sa</password>
</security>
</datasource>
<datasource jta="false" jndi-name="java:/jdbc/PegaRULES" pool-name="PegaRULES" enabled="true" use-ccm="false">
<connection-url>jdbc:sqlserver://localhost:1433;databaseName=PRPC_73_JBOSS;selectMethod=cursor;sendStringParametersAsUnicode=false</connection-url>
<driver-class>com.microsoft.sqlserver.jdbc.SQLServerDriver</driver-class>
<driver>mssql</driver>
<pool>
<max-pool-size>100</max-pool-size>
</pool>
<security>
<user-name>PRPC_73_JBOSS</user-name>
<password>PRPC_73_JBOSS</password>
</security>
<validation>
<validate-on-match>false</validate-on-match>
<background-validation>false</background-validation>
</validation>
<statement>
<share-prepared-statements>false</share-prepared-statements>
</statement>
</datasource>
<datasource jta="false" jndi-name="java:/jdbc/AdminPegaRULES" pool-name="AdminPegaRULES" enabled="true" use-ccm="false">
<pool>
</pool>
<security>
</security>
<validation>
</validation>
<statement>
</statement>
</datasource>
<drivers>
<driver name="h2" module="com.h2database.h2">
<xa-datasource-class>org.h2.jdbcx.JdbcDataSource</xa-datasource-class>
</driver>
<driver name="mssql" module="com.mssql">
</driver>
<driver name="microsoft" module="com.mssql"/>
</drivers>
</datasources>
</subsystem>
<subsystem xmlns="urn:jboss:domain:deployment-scanner:1.1">
<deployment-scanner path="deployments" relative-to="jboss.server.base.dir" scan-interval="5000"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:ee:1.2">
<spec-descriptor-property-replacement>false</spec-descriptor-property-replacement>
<jboss-descriptor-property-replacement>true</jboss-descriptor-property-replacement>
<annotation-property-replacement>false</annotation-property-replacement>
</subsystem>
<subsystem xmlns="urn:jboss:domain:ejb3:1.5">
<session-bean>
<stateless>
<bean-instance-pool-ref pool-name="slsb-strict-max-pool"/>
</stateless>
<stateful default-access-timeout="5000" cache-ref="simple"/>
<singleton default-access-timeout="5000"/>
</session-bean>
<mdb>
<resource-adapter-ref resource-adapter-name="${ejb.resource-adapter-name:hornetq-ra}"/>
<bean-instance-pool-ref pool-name="mdb-strict-max-pool"/>
</mdb>
<pools>
<bean-instance-pools>
<strict-max-pool name="slsb-strict-max-pool" max-pool-size="20" instance-acquisition-timeout="5" instance-acquisition-timeout-unit="MINUTES"/>
<strict-max-pool name="mdb-strict-max-pool" max-pool-size="20" instance-acquisition-timeout="5" instance-acquisition-timeout-unit="MINUTES"/>
</bean-instance-pools>
</pools>
<caches>
<cache name="simple" aliases="NoPassivationCache"/>
<cache name="passivating" passivation-store-ref="file" aliases="SimpleStatefulCache"/>
</caches>
<passivation-stores>
<file-passivation-store name="file"/>
</passivation-stores>
<async thread-pool-name="default"/>
<timer-service thread-pool-name="default" default-data-store="default-file-store">
<data-stores>
<file-data-store name="default-file-store" path="timer-service-data" relative-to="jboss.server.data.dir"/>
</data-stores>
</timer-service>
<remote connector-ref="remoting-connector" thread-pool-name="default"/>
<thread-pools>
<thread-pool name="default">
<max-threads count="10"/>
<keepalive-time time="100" unit="milliseconds"/>
</thread-pool>
</thread-pools>
<iiop enable-by-default="false" use-qualified-name="false"/>
<default-security-domain value="other"/>
<default-missing-method-permissions-deny-access value="true"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:infinispan:1.5">
<cache-container name="web" aliases="standard-session-cache" default-cache="local-web" module="org.jboss.as.clustering.web.infinispan">
<local-cache name="local-web" batching="true">
<file-store passivation="false" purge="false"/>
</local-cache>
</cache-container>
<cache-container name="hibernate" default-cache="local-query" module="org.jboss.as.jpa.hibernate:4">
<local-cache name="entity">
<transaction mode="NON_XA"/>
<eviction strategy="LRU" max-entries="10000"/>
<expiration max-idle="100000"/>
</local-cache>
<local-cache name="local-query">
<transaction mode="NONE"/>
</local-cache>
<local-cache name="timestamps">
<eviction strategy="NONE"/>
</local-cache>
</cache-container>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jacorb:1.4">
<orb socket-binding="jacorb" ssl-socket-binding="jacorb-ssl">
<initializers security="identity" transactions="spec"/>
</orb>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jaxr:1.1">
<connection-factory jndi-name="java:jboss/jaxr/ConnectionFactory"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jaxrs:1.0"/>
<subsystem xmlns="urn:jboss:domain:jca:1.1">
<archive-validation enabled="true" fail-on-error="true" fail-on-warn="false"/>
<bean-validation enabled="true"/>
<default-workmanager>
<short-running-threads>
<core-threads count="50"/>
<queue-length count="50"/>
<max-threads count="50"/>
<keepalive-time time="10" unit="seconds"/>
</short-running-threads>
<long-running-threads>
</long-running-threads>
</default-workmanager>
<cached-connection-manager/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jdr:1.0"/>
<subsystem xmlns="urn:jboss:domain:jmx:1.3">
<expose-resolved-model/>
<expose-expression-model/>
<remoting-connector/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jpa:1.1">
<jpa default-datasource="" default-extended-persistence-inheritance="DEEP"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jsf:1.0"/>
<subsystem xmlns="urn:jboss:domain:jsr77:1.0"/>
<subsystem xmlns="urn:jboss:domain:mail:1.2">
<mail-session name="default" jndi-name="java:jboss/mail/Default">
<smtp-server outbound-socket-binding-ref="mail-smtp"/>
</mail-session>
</subsystem>
<subsystem xmlns="urn:jboss:domain:messaging:1.4">
<hornetq-server>
<persistence-enabled>true</persistence-enabled>
<security-enabled>false</security-enabled>
<journal-type>NIO</journal-type>
<journal-min-files>2</journal-min-files>
<connectors>
<netty-connector name="netty" socket-binding="messaging"/>
<netty-connector name="netty-throughput" socket-binding="messaging-throughput">
<param key="batch-delay" value="50"/>
</netty-connector>
<in-vm-connector name="in-vm" server-id="0"/>
</connectors>
<acceptors>
<netty-acceptor name="netty" socket-binding="messaging"/>
<netty-acceptor name="netty-throughput" socket-binding="messaging-throughput">
<param key="direct-deliver" value="false"/>
</netty-acceptor>
<in-vm-acceptor name="in-vm" server-id="0"/>
</acceptors>
<security-settings>
<security-setting match="#">
<permission type="send" roles="guest"/>
<permission type="consume" roles="guest"/>
<permission type="createNonDurableQueue" roles="guest"/>
<permission type="deleteNonDurableQueue" roles="guest"/>
</security-setting>
</security-settings>
<address-settings>
<address-setting match="#">
<dead-letter-address>jms.queue.DLQ</dead-letter-address>
<expiry-address>jms.queue.ExpiryQueue</expiry-address>
<redelivery-delay>0</redelivery-delay>
<max-size-bytes>10485760</max-size-bytes>
<page-size-bytes>2097152</page-size-bytes>
<address-full-policy>PAGE</address-full-policy>
<message-counter-history-day-limit>10</message-counter-history-day-limit>
</address-setting>
</address-settings>
<jms-connection-factories>
<connection-factory name="InVmConnectionFactory">
<connectors>
<connector-ref connector-name="in-vm"/>
</connectors>
<entries>
<entry name="java:/ConnectionFactory"/>
</entries>
</connection-factory>
<connection-factory name="RemoteConnectionFactory">
<connectors>
<connector-ref connector-name="netty"/>
</connectors>
<entries>
<entry name="java:jboss/exported/jms/RemoteConnectionFactory"/>
</entries>
<pooled-connection-factory name="hornetq-ra">
<transaction mode="xa"/>
<connectors>
</connectors>
<entries>
<entry name="java:/JmsXA"/>
</entries>
</pooled-connection-factory>
<pooled-connection-factory name="AsyncConnectionFactory">
<connectors>
</connectors>
<entries>
<entry name="java:/jms/PRAsyncTCF"/>
</entries>
</jms-connection-factories>
<jms-destinations>
<jms-queue name="ExpiryQueue">
<entry name="java:/jms/queue/ExpiryQueue"/>
</jms-queue>
<jms-queue name="DLQ">
<entry name="java:/jms/queue/DLQ"/>
</jms-queue>
</jms-destinations>
</hornetq-server>
</subsystem>
<subsystem xmlns="urn:jboss:domain:naming:1.4">
<bindings>
<simple name="java:/prconfig/database/databases/PegaRULES/defaultSchema" value="RULES"/>
<simple name="java:/prconfig/database/databases/PegaDATA/defaultSchema" value="DATA"/>
<simple name="java:/url/pega/none" value="file:/nul"/>
</bindings>
</subsystem>
<subsystem xmlns="urn:jboss:domain:pojo:1.0"/>
<subsystem xmlns="urn:jboss:domain:remoting:1.2">
<connector name="remoting-connector" socket-binding="remoting" security-realm="ApplicationRealm"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:resource-adapters:1.1"/>
<subsystem xmlns="urn:jboss:domain:sar:1.0"/>
<subsystem xmlns="urn:jboss:domain:security:1.2">
<security-domains>
<security-domain name="other" cache-type="default">
<authentication>
<login-module code="Remoting" flag="optional">
<module-option name="password-stacking" value="useFirstPass"/>
</login-module>
<login-module code="RealmDirect" flag="required">
</login-module>
</authentication>
</security-domain>
<security-domain name="jboss-web-policy" cache-type="default">
<authorization>
<policy-module code="Delegating" flag="required"/>
</authorization>
</security-domain>
<security-domain name="jboss-ejb-policy" cache-type="default">
<authorization>
</authorization>
</security-domain>
</security-domains>
</subsystem>
<subsystem xmlns="urn:jboss:domain:threads:1.1"/>
<subsystem xmlns="urn:jboss:domain:transactions:1.5">
<core-environment>
<process-id>
<uuid/>
</process-id>
</core-environment>
<recovery-environment socket-binding="txn-recovery-environment" status-socket-binding="txn-status-manager"/>
<coordinator-environment default-timeout="300"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:web:2.2" default-virtual-server="default-host" native="false">
<connector name="http" protocol="HTTP/1.1" scheme="http" socket-binding="http"/>
<virtual-server name="default-host" enable-welcome-root="true">
<alias name="localhost"/>
<alias name="example.com"/>
</virtual-server>
</subsystem>
<subsystem xmlns="urn:jboss:domain:webservices:1.2">
<modify-wsdl-address>true</modify-wsdl-address>
<wsdl-host>${jboss.bind.address: Proprietary information hidden}</wsdl-host>
<endpoint-config name="Standard-Endpoint-Config"/>
<endpoint-config name="Recording-Endpoint-Config">
<pre-handler-chain name="recording-handlers" protocol-bindings="##SOAP11_HTTP ##SOAP11_HTTP_MTOM ##SOAP12_HTTP ##SOAP12_HTTP_MTOM">
<handler name="RecordingHandler" class="org.jboss.ws.common.invocation.RecordingServerHandler"/>
</pre-handler-chain>
</endpoint-config>
<client-config name="Standard-Client-Config"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:weld:1.0"/>
</profile>
<interfaces>
<interface name="management">
<inet-address value="${jboss.bind.address.management: Proprietary information hidden}"/>
</interface>
<interface name="public">
<inet-address value="${jboss.bind.address: Proprietary information hidden}"/>
</interface>
<interface name="unsecure">
<inet-address value="${jboss.bind.address.unsecure: Proprietary information hidden}"/>
</interface>
</interfaces>
<socket-binding-group name="standard-sockets" default-interface="public" port-offset="${jboss.socket.binding.port-offset:0}">
<socket-binding name="management-native" interface="management" port="${jboss.management.native.port:9999}"/>
<socket-binding name="management-http" interface="management" port="${jboss.management.http.port:9990}"/>
<socket-binding name="management-https" interface="management" port="${jboss.management.https.port:9443}"/>
<socket-binding name="ajp" port="8009"/>
<socket-binding name="http" port="8080"/>
<socket-binding name="https" port="8443"/>
<socket-binding name="jacorb" interface="unsecure" port="3528"/>
<socket-binding name="jacorb-ssl" interface="unsecure" port="3529"/>
<socket-binding name="messaging" port="5445"/>
<socket-binding name="messaging-group" port="0" multicast-address="${jboss.messaging.group.address: Proprietary information hidden}" multicast-port="${jboss.messaging.group.port:9876}"/>
<socket-binding name="messaging-throughput" port="5455"/>
<socket-binding name="remoting" port="4447"/>
<socket-binding name="txn-recovery-environment" port="4712"/>
<socket-binding name="txn-status-manager" port="4713"/>
<outbound-socket-binding name="mail-smtp">
<remote-destination host="localhost" port="25"/>
</outbound-socket-binding>
</socket-binding-group>
<deployments>
<deployment name="prpc_j2ee14_jboss61JBM.ear" runtime-name="prpc_j2ee14_jboss61JBM.ear">
<content sha1="bdc8455100a5e41a1431b69cb5f36778b75a6253"/>
</deployment>
<deployment name="prsysmgmt.war" runtime-name="prsysmgmt.war">
<content sha1="c9be05a696e61588c28225dcf129703956ab8ad9"/>
</deployment>
<deployment name="prhelp.war" runtime-name="prhelp.war">
<content sha1="2f2017db6894b13cf4b243194378a238a8d6fded"/>
</deployment>
</deployments>
</server>
Updated: 17 Nov 2017 4:47 EST
Bank Sinarmas
ID
Sorry for late reply, been so busy yesterday. here is my standalone-full.xml.
single schema, single user, fresh installation.
<extensions>
</extensions><management>
<security-realms>
<authentication>
</authentication>
</authorization>
</security-realm>
<authentication>
</authentication>
<authorization>
</authorization>
</security-realm>
</security-realms>
<audit-log>
<formatters>
</formatters>
<handlers>
</handlers>
<handlers>
</handlers>
</logger>
</audit-log>
</native-interface>
</http-interface>
<role-mapping>
<include>
</include>
</role>
</role-mapping>
</access-control>
</management><profile>
<formatter>
</formatter>
</console-handler>
<formatter>
</formatter>
</logger>
</logger>
</logger>
</logger>
</logger>
</logger>
<root-logger>
<handlers>
</handlers>
</root-logger>
</formatter>
</formatter>
</subsystem>
<datasources>
<driver>h2</driver>
<security>
</security>
</datasource>
<datasource jta="true" jndi-name="java:jboss/PegaRULES" pool-name="PegaRULES" enabled="true" use-ccm="false">
<connection-url>jdbc:oracle:thin:@localhost:1521:pegajboss</connection-url>
<driver-class>oracle.jdbc.OracleDriver</driver-class>
<driver>oracle</driver>
<pool>
<min-pool-size>30</min-pool-size>
</pool>
<security>
<user-name>pegajboss</user-name>
<password>Pegajboss123</password>
</security>
<validation>
<valid-connection-checker class-name="org.jboss.jca.adapters.jdbc.extensions.oracle.OracleValidConnectionChecker"/>
<background-validation>true</background-validation>
<stale-connection-checker class-name="org.jboss.jca.adapters.jdbc.extensions.oracle.OracleStaleConnectionChecker"/>
<exception-sorter class-name="org.jboss.jca.adapters.jdbc.extensions.oracle.OracleExceptionSorter"/>
</validation>
</datasource>
<datasource jta="true" jndi-name="java:jboss/AdminPegaRULES" pool-name="AdminPegaRULES" enabled="true" use-ccm="false">
<connection-url>jdbc:oracle:thin:@ :1521:pegajboss</connection-url>
<driver-class>oracle.jdbc.driver.OracleDriver</driver-class>
<security>
</security>
<validation>
</validation>
</datasource>
<drivers>
</driver>
<driver name="oracle" module="oracle.jdbc">
<xa-datasource-class>oracle.jdbc.xa.client.OracleXADataSource</xa-datasource-class>
</driver>
</drivers>
</datasources>
</subsystem>
</subsystem>
</subsystem>
<session-bean>
<stateless>
</stateless>
</session-bean>
<mdb>
</mdb>
<pools>
</pools>
<caches>
</caches>
<data-stores>
</data-stores>
</timer-service>
<thread-pools>
</thread-pool>
</thread-pools>
</subsystem>
</local-cache>
</cache-container>
</local-cache>
</local-cache>
</local-cache>
</cache-container>
</subsystem>
</orb>
</subsystem>
</subsystem>
</subsystem>
</subsystem>
</subsystem>
</mail-session>
</subsystem>
<hornetq-server>
<journal-min-files>2</journal-min-files><connectors>
</netty-connector>
</connectors><acceptors>
</netty-acceptor>
</acceptors><security-settings>
</security-setting>
</security-settings><address-settings>
</address-setting>
</address-settings><jms-connection-factories>
<connectors>
</connectors>
<entries>
</entries>
<connectors>
</connectors>
<entries>
</entries>
<connectors>
</connectors>
<entries>
</entries>
</jms-connection-factories><jms-destinations>
</jms-queue>
</jms-queue>
</jms-destinations>
</hornetq-server>
</subsystem>
<bindings>
<simple name="java:/prconfig/database/databases/PegaRULES/defaultSchema" value="pegarules"/>
<simple name="java:/prconfig/database/databases/PegaDATA/defaultSchema" value="pegadata"/>
</bindings>
<remote-naming/>
</subsystem>
</subsystem>
<security-domains>
<authentication>
</login-module>
</login-module>
</authentication>
</security-domain>
<authorization>
</authorization>
</security-domain>
<authorization>
</authorization>
</security-domain>
</security-domains>
</subsystem>
<core-environment>
<process-id>
<uuid/>
</process-id>
</core-environment>
</subsystem>
</virtual-server>
</subsystem>
</endpoint-config>
</subsystem>
</profile><interfaces>
</interface>
</interface>
</interface>
</interfaces><socket-binding-group name="standard-sockets" default-interface="public" port-offset="${jboss.socket.binding.port-offset:0}">
<socket-binding name="management-http" interface="public" port="${jboss.management.http.port:9990}"/>
<socket-binding name="messaging-group" port="0" multicast-address="${jboss.messaging.group.address: }" multicast-port="${jboss.messaging.group.port:9876}"/>
</server>
Kumari Sneha Sujith Vankadari Siddharth Chaurasia
Hi Julian,
After analyzing your shared file noticed few things as follows:
Hi Julian,
- As you specified that you are using single user there is no need for the AdminPegaRULES datasource configuration as explained in the installation guide.
- Also i can see some issues with the PegaRULES datasource configuration and some of them are explained below,
- <datasource jta="true" jndi-name="java:jboss/PegaRULES" -> <datasource jta="false" jndi-name="java:jdbc/PegaRULES"
- jdbc:oracle:thin:@localhost:1521:pegajboss -> jdbc:oracle:thin:@localhost:1521/service-name or jdbc:oracle:thin:@localhost:1521:SID
- validation element also not matching with the guide specific properties, not sure whether you are using the custom validations.
- As you are using the XA Data source the driver module name is specified incorrectly as shown below,
- <driver name="oracle" module="oracle.jdbc"> -> <driver name="oracle" module="com.oracle">
- You had specified that you are using the single schema, so the rules and data schema configurations should point to single schema name as shown below,
- <simple name="java:/prconfig/database/databases/PegaRULES/defaultSchema" value="pegarules"/> -> here you should give your schema name
- <simple name="java:/prconfig/database/databases/PegaDATA/defaultSchema" value="pegadata"/> -> here you should give your schema name
Note: This information is provided based on the high level overview of your configuration file with reference to the latest Pega version as i am not aware of your version of pega. So, i would suggest you to cross check with the installation guide for the version which you are trying to install so that it will be more near to your configurations for cross verifications.
Hope this information might help you to resolve your issues.
Regards
Mahesh
