How to Display the Tabs dynamically, meaning each document should open in a seperate Tab on UI in Pega 7.3
I used to achieve this functionality using Tab group and a dynamic container in pega 7.1.x versions. But Tab group is deprecated in 7.3 . Can anyone tell me if there is any other alternative to Tab group in pega 7.3 to display each document in a seperate Tab dynamically.
Hi Vamsi,
You can use the Layout group with category as "Tab" to implement the Tab layout.
Evita.
