Virtusa
LK
Last activity: 10 Dec 2018 2:05 EST
DevOps implementation
I configure devops by going through following links.
But didn't successfully completed following error occurs.Please provide help for the current issue
Hi Sameera,
Fyi, i had shared the successfully implemented using jenkins-build.xml file along with the process document for import/export in my blog which you have shared above. I would suggest you to cross check with my jenkins-build.xml file as i can see so many differences with your build file.
Regards
Mahesh
Looks like there is an issue in build file. Request validation url is empty. Could you please check the build file and provide the correct details.
Virtusa
LK
How to find the proper jenkin-build.xml format.
Updated: 25 Oct 2017 5:33 EDT
Virtusa
LK
Bellow is my jenkins-build.xml file.After setting prpcServiceUtils.properties.xml file in prpcServiceUtils only pega.rest.server.url get the url and also other properties.
Hi Sameera,
Regards
Mahesh
Virtusa
LK
Thank you.
ASN Bank
Hi Mahesh,
Can you share the link which you are saying is posted in you blog.
Regard
Gouri Shankar K
Here's the link to his blog: [Procedure] Export & Import using prpcServiceUtils from Jenkins in Pega v7.2.2
He has also posted:
Export & Import multiple Product rules using prpcServiceUtils from Jenkins in Pega v7.2.2
Cleveland State University
I am having a similar issue. My url is not completely empty, but it say illegal arguments.
15:51:49 [echo] *** JVM Arguments -XX:MaxHeapSize=1280m *** 15:51:49 15:51:49 _callService: 15:51:50 [java] 15:51:50.499 [main] INFO [a.pegarules.serviceclient.ClientSettings] - -action export -propFileDir C:\prpcServiceUtils\scripts\utils/generated -poolSize ${prpcserviceutils.pool.size} -requestTimeOut ${prpcserviceutils.request.timeout} -tempDir C:\windows\TEMP\/PegaInstallTemp-06-December-2018-15.51.48 -artifactsDir C:\prpcServiceUtils 15:51:50 [java] 15:51:50.510 [main] INFO [a.pegarules.serviceclient.ClientSettings] - Setting Thread Pool Size to default 5 15:51:50 [java] 15:51:50.510 [main] INFO [a.pegarules.serviceclient.ClientSettings] - Setting Request TimeOut to default 300 15:51:50 [java] 15:51:50.523 [main] INFO [.pega.pegarules.serviceclient.ClientMain] - Initializing client Current Operation = EXPORT; Thread Pool Size = 5; RequestTimeOut = 300; TemporaryDirectory = C:\windows\TEMP\/PegaInstallTemp-06-December-2018-15.51.48 15:51:50 [java] 15:51:50.525 [main] INFO [viceclient.requestmanager.RequestManager] - Initializing Request Manager 15:51:50 [java] 15:51:50.527 [main] INFO [viceclient.requestmanager.RequestManager] - Initializing ExecutorService with pool size 5 15:51:50 [java] 15:51:50.532 [main] INFO [viceclient.requestmanager.RequestManager] - Performing EXPORT with params [System Name = jenkins-freeJob1-23 Parameters = {export.async=false, manageRestorePoints.restorePointLabel=, user.temp.dir=C:/pega_temp, import.commitRate=100, hotfix.bypassSchema=false, pega.rest.password=*****, import.allowInheritedConnections=false, pega.rest.response.type=json, import.mode=import, import.nofailonerror=false, export.branchAppContext=, hotfix.force=false, import.importFromRepository=false, export.applicationVersion=${applicationVersion}, pega.rest.username=0000000, expose.reindexType=nonpega, export.exportToRepository=false, pega.rest.proxy.port=, hotfix.async=true, import.archive.path=, import.compileLibraries=true, import.insecureOperators=, rollback.downloadLogToFile=true, export.productName=EBS, expose.async=true, updateAccessGroup.applicationVersion=, import.preserveOrder=true, getstatus.operationName=, export.branchName=, expose.startDate=, export.productVersion=01.01.04, import.allowImportWithMissingDependencies=false, rollback.async=true, expose.reindex=true, updateAccessGroup.applicationName=, expose.includedClasses=, updateAccessGroup.groupList=, expose.endKey=, expose.excludeDescendents=true, expose.numOfThreads=1, export.archiveName=EBS01.01.04, getstatus.jobID=, expose.excludedClasses=, import.artifactType=, expose.includeDescendents=true, pega.rest.server.url=c0000000.test.abcd.pqrs.com:8080/prweb/PRRestService/, import.existingInstances=skip, manageRestorePoints.restorePointName=, import.async=true, expose.endDate=, rollback.restorePointName=, manageTrackedData.operation=, hotfix.dlFilePath=, import.skipBackup=false, pega.rest.proxy.workstation=, pega.rest.proxy.password=*****, import.archivePath=, hotfix.catalogPath=, import.codesetName=Customer, hotfix.operation=, pega.rest.proxy.domain=, expose.commitRate=100, pega.rest.proxy.host=, import.repositoryName=, rollback.action=SystemRollback, export.applicationName=${applicationName}, expose.startKey=, manageRestorePoints.action=, pega.rest.proxy.username=, export.repositoryName=, import.codesetVersion=06-01-01, import.bypassSchema=}] 15:51:50 [java] 15:51:50.544 [main] INFO [viceclient.requestmanager.RequestManager] - Request on system jenkins-freeJob1-23 failed 15:51:50 [java] 15:51:50.545 [main] ERROR [viceclient.requestmanager.RequestManager] - Request on system jenkins-freeJob1-23 failed 15:51:50 [java] java.util.concurrent.ExecutionException: java.lang.IllegalArgumentException: Invalid URL provided for system jenkins-freeJob1-23 URL:c0000000.test.abcd.pqrs.com:8080/prweb/PRRestService/ 15:51:50 [java] at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:1.8.0_192] 15:51:50 [java] at java.util.concurrent.FutureTask.get(FutureTask.java:206) ~[?:1.8.0_192] 15:51:50 [java] at com.pega.pegarules.serviceclient.requestmanager.RequestManager.processResponse(RequestManager.java:156) [prdeploy.jar:?] 15:51:50 [java] at com.pega.pegarules.serviceclient.requestmanager.RequestManager.doOperation(RequestManager.java:141) [prdeploy.jar:?] 15:51:50 [java] at com.pega.pegarules.serviceclient.ClientMain.executeAndHandleResponse(ClientMain.java:100) [prdeploy.jar:?] 15:51:50 [java] at com.pega.pegarules.serviceclient.ClientMain.main(ClientMain.java:61) [prdeploy.jar:?] 15:51:50 [java] Caused by: java.lang.IllegalArgumentException: Invalid URL provided for system jenkins-freeJob1-23 URL:c0000000.test.abcd.pqrs.com:8080/prweb/PRRestService/ 15:51:50 [java] at com.pega.pegarules.serviceclient.operation.AbstractOperation.parseURL(AbstractOperation.java:97) ~[prdeploy.jar:?] 15:51:50 [java] at com.pega.pegarules.serviceclient.operation.AbstractOperation.validateInputParameters(AbstractOperation.java:229) ~[prdeploy.jar:?] 15:51:50 [java] at com.pega.pegarules.serviceclient.rest.RestRequest.validateInputParameters(RestRequest.java:41) ~[prdeploy.jar:?] 15:51:50 [java] at com.pega.pegarules.serviceclient.rest.AbstractRestRequest.execute(AbstractRestRequest.java:56) ~[prdeploy.jar:?] 15:51:50 [java] at com.pega.pegarules.serviceclient.rest.AbstractRestRequest.execute(AbstractRestRequest.java:1) ~[prdeploy.jar:?] 15:51:50 [java] at com.pega.pegarules.serviceclient.request.AbstractRequest.call(AbstractRequest.java:62) ~[prdeploy.jar:?] 15:51:50 [java] at com.pega.pegarules.serviceclient.request.AbstractRequest.call(AbstractRequest.java:1) ~[prdeploy.jar:?] 15:51:50 [java] at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_192] 15:51:50 [java] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_192] 15:51:50 [java] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_192] 15:51:50 [java] at java.lang.Thread.run(Thread.java:748) ~[?:1.8.0_192]
15:51:50 [java] FAILED JOBS 15:51:50 [java] -------------------------------------------------------------------------------------------- 15:51:50 [java] 15:51:50 [java] System Name : jenkins-freeJob1-23 15:51:50 [java] Job ID : 15:51:50 [java] Status : 15:51:50 [java] Error Messages : REQUEST_VALIDATION_ERROR java.lang.IllegalArgumentException: Invalid URL provided for system jenkins-freeJob1-23 URL:c0000000.test.abcd.pqrs.com:8080/prweb/PRRestService/ 15:51:50 [java] -------------------------------------------------------------------------------------------- 15:51:50 [java] 15:51:50.597 [main] INFO [viceclient.requestmanager.RequestManager] - Shutting down executor service 15:51:50 [java] 15:51:50.597 [main] INFO [viceclient.requestmanager.RequestManager] - Executor Service shutdown completed 15:51:50 [java] Exception in thread "main" Operation EXPORT failed on jenkins-freeJob1-23, 15:51:50 [java] at com.pega.pegarules.serviceclient.ClientMain.executeAndHandleResponse(ClientMain.java:116) 15:51:50 [java] at com.pega.pegarules.serviceclient.ClientMain.main(ClientMain.java:61) 15:51:50 [java] Picked up _JAVA_OPTIONS: -Xmx512M 15:51:50 15:51:50 BUILD FAILED 15:51:50 C:\prpcServiceUtils\scripts\utils\prpcserviceutilsWrapper.xml:176: The following error occurred while executing this line: 15:51:50 C:\prpcServiceUtils\scripts\utils\prpcserviceutilsWrapper.xml:194: Java returned: 1 15:51:50 15:51:50 Total time: 2 seconds 15:51:50 Picked up _JAVA_OPTIONS: -Xmx512M 15:51:50 Exiting with Error 15:51:50 15:51:50 Build step 'Execute Windows batch command' marked build as failure 15:51:51 Finished: FAILURE
Hello!
We see that you have created a new post for this query: Jenkins Error using prpcServiceUtils
Good practice!
Kelly Lucas Sunil M Kale
