Swedish Unemployment Funds
SE
Last activity: 6 Oct 2017 9:20 EDT
Enable upgrades when using multiple Datasources
We have an application utilising 27 implementation layers. We tried putting each implemetation layers work/work_history tables in separate database schemas using different Datasources to address these tables. Worked a charm until we tried upgrading (Pega 7.2.0 to 7.2.1) where the upgrade process crashed due to more than one data schema. Now we have a business case where we need to constantly cull (resolved) data from the work tables into separate archive db. This calls for using alternative datasources again. The question in the SR was if you now support using multiple datasources also when upgrading. apparently not. We find this strange that you support it when running the application but not in the upgrade process. Therefore we request that you amend the upgrade process to support usage of multiple datasources.
We use the Installation and Upgrade Assistant (IUA) tool when upgrading
