NoHttpResponseException & Unexpected HTTP 403 Response code
Facing below issues, I have been trying to install package in multiple instances. Server - A has been configured on PEGA instance - 7.2.2 where as Client (B & C) has been configured on instance 7.1.n versions of pega.
1) Server - A & Client B are configured and while defining release (as part of Step- configure Applications Environment & Release Details (on Release Management Server)) facing below issue:
** Unable to check platform REST service due to com.pega.pegarules.pub.services.ConnectorException: Caught unhandled exception: java.lang.RuntimeException: org.apache.http.NoHttpResponseException: nn.nnn.nnn.nnnn:8307 failed to respond
2) Server - A & Client c are configured, facing below issue while doing test connection from Server to Client:
“Instance Connection Info :Fail: Unexpected HTTP 403 Response code the HTTP response code of 403 indicated a client error. The response data may contain a reason.”
Any help will be appreciated.
