Accenture
Invalid clipboard stream detected in module StorageStreamCommon.create(byte []). Reason: Invalid signature found in stream. Stream length = XXXXXXX; signature: @å; compressed = false
As part of DB data maintenance activity, Reorg with Syntax AUX = YES done on couple of application tables. At the same point of time few records were in process update from FE app. This reorg activity resulted missing blob file (PZPVSTREAM) from DB and work objects were not accessible from any DB tools and also from FE application.
DB team worked, collected binary file from logs and inserted / update BLOB data (PZPVSTREAM) into tables on missing column.
Once (PZPVSTREAM) is available now, we are able to search from DB tools but PEGA 7.1 application is returning listed error message and WO is not accessible for end users.
Step Status Info :
Invalid clipboard stream detected in module StorageStreamCommon.create(byte []). Reason: Invalid signature found in stream. Stream length = 30524; signature: @å; compressed = false
Obj-Open-By-Handle :
Step Status Info :
High Level Op ID | 25 |
High Level Op | open instance of class Rule-Message by keys |
Note | Looking for instance Rule-Message RULE-MESSAGE INVALIDSTREAM #20130918T235114.936 GMT in the Instance cache |
Object Class | Rule-Message |
