SINARMASMSIGLIFE
ID
Last activity: 11 Oct 2017 21:24 EDT
Configure My Rules
hi,
Please check these articles :
https://pdn.pega.com/delegating-record
https://docs-previous.pega.com/working-delegations
Santhosh
You can add privilege in the access role . Please go the respective users access group and drill down to their Acces role.
SINARMASMSIGLIFE
ID
hi santanu,
You have to add the required privileges to roles that Manager and Operator has. Open Manager/Operator's access group and check the roles he/she has. Update one of them to grant the required privileges.
Additional info: https://collaborate.pega.com/question/which-role-have-access-delegation-rules
Santhosh
Vachan Chauhan
SINARMASMSIGLIFE
ID
hi bagas, I have done what is in the reference (the reference is the same as in prhelp), but still don't understand where should i put in access role that privileges .
thanks
pxCanDelegateRules should be added to Rule- RARO and ToolbarFull should be added on @baseclass.
Santhosh
SINARMASMSIGLIFE
ID
hi bagas,
thanks for the information,
is that meaning of RARO Rule-Access-Role-Object ?? and may I know, about this setting (attachment) ?
thanks before.
Yes, it is Rule-Access-Role-Object. You have to check in your role that if a RARO is already present for class "Rule-" or not. If it is, you can update it to add the required privilege. If not, create one on Rule- class and add the required privilege. By default, PegaRULES:SysAdm4 contains a RARO for Rule- class. You can use it for reference.
Santhosh
SINARMASMSIGLIFE
ID
hi bagas,
I've tried what is referenced, but it's still unclear how to use it in manager portal.
can you give an example for configuration it ? ( i attch screenshoot )
thanks
Santhosh
Julien FREMEAU
SINARMASMSIGLIFE
ID
hi bagas
thanks about the articles , very helpful in explaining about my rules.
Bruce Steward vimala ponnambalam Aulia Rahmadi Vinay Chowdary Sarupuru
