Document Handling Design Question
Our workflow application uses the document upload feature to allow users to attach files to a work object. The category value list is used to indicate the document type for further handling in the workflow. In some cases due to document size, the users choose to upload an entire set of documents into a general category instead of separating them by document type.
Our challenge is to create a design which allows for dynamic separation of a bulk upload and assignment into their respective document types. We have investigated using some sort of bar code embedded into the first page header of each document, but not quite sure if PRPC can recognize and handle this. Any suggestions or leads you can share are appreciated. Thank you.
