RDA - Windows adapter start path in 32 bit/64 bit ProgramFiles
If same windows application has to be launched on 32 bit and 64 bit machines, is there any way to make one solution work for both? We need to select absolute path during design time on developer machine pointing to C:\Program Files (x86)\<Folder>\executable.exe but on a 32 bit user machine it is C:\Program Files\<Folder>\executable.exe. I cant save adapter rule with environment variables like %programfiles%", "%programfiles(x86)%", "%ProgramFiles%", "%commonprogramfiles%", "%COMMONPROGRAMFILES%. The Folder option in Path property points to standard system folders like Program Files, Desktop etc but at runtime the executable is looked up directly as C:\Program Files\executable.exe.
Is there any solution other than creating 2 versions of the deployment package ?
