Entry Point Not Found - OpenSpan.Scout dll related
I've just converted by OpenSpan plug in solution (which contains to projects - 1 Visual Studio and 1 OpenSpan) from 7.193 to 8.0.143. The Solution builds with no errors. When trying to run the project I receive the following message (if run on a 32 bit machine I receive the same message but for OpenSpan.Scout.x32.dll):
After click OK on the above message, I then receive this Fatal Error:
The V-SIST project is the Visual Studio project and the Vertex_Smithfield_Project is the OpenSpan project. I recently converted a similar project (this on is a subset of that project basically), and did not and do not have this issue. How can I correct this?
