Wipro Ltd
Pega 7.3 Installation
Hi Team I need help to install Pega 7.3 Personal Edition. I downloaded it and it is around 4.7GB. After Installation I clicked in insall.bat file but is within a span of 1 sec it is closing down. Could you please help me?
***Edited by moderator, Maryrita: moved to Product Support from Applications***
PEG
PL
This could be because of java service not started. May be because of:
1) java is not there.
2) The reason could be, the tomcat folder will have some java heap setting. That heap might be more and your computer is not able to reserve that much space.
Try to investigate on this front.
Wipro Ltd
I installed Java on my machine.
I didn't get the second pointer..Could you please help more on understanding this.
OCBC Bank
SG
Hi Yogesh,
Can you try running install.bat from command prompt, this will show the error message if any and the screen doesnt close. Run>cmd. Navigate to \script folder in pega media and run install.bat
I guess you might be getting below error and the window closes
"Invoke our ant script, passing in the arguments as collected
Access is denied."
The install/upgrade scripts are ANT scripts and they will be looking for ANT_HOME variable to be set.
Also make sure you have JAVA_HOME set to supported Java installation in your environment variables
Wipro Ltd
Hi Sandeep,
Thank You for your reply.
I am not able to find Script folder. and not able to understand.
Wipro Ltd
Hi
I got this error-
F:\115490_PE7.3>install.bat
This version of F:\115490_PE7.3\jdk1.8.0_121\bin\java.exe is not compatible with
the version of Windows you're running. Check your computer's system information
to see whether you need a x86 (32-bit) or x64 (64-bit) version of the program,
and then contact the software publisher.
Is there any way we can install in 32 Bit?
Hi Yogesh,
I think you can't install pega 7.3 in a 32-bit machine. You can install it in 64-bit machine.
Please try installing it in a 64-bit machine.
Softdel
Hi Yogesh
you can copy the Pega 7.3 folder on desktop and then install. There should not be any space in path.
Wipro Technologies Ltd
Whike i am trying to install pega 7.3.1 i am getting error inspite of trying it many times.Please try to resolve my issue
Hi Joseph,
It seems that you facing issue while starting the DB server.
Could you please cross verify with the installation guide if you have configured the DB correctly.
Also could you please make sure if pg_ctl is present in your configuration file (it should be inside the bin folder).
If it is present could you please try running pg_ctl manually once and see if it is running or not?
Vikash
As per the stack trace "data" folder already contains some file folders .Please delete content of below folder and then execute installation again
C:\PRPCPersonalEdition\pgsql\data
Abhinav
