Capgemini
How to integrate Pega Agile Studio with Pega 7.3 Personal edition
I am using pega 7.3 personal edition. How can I integrate Pega Agile Studio with the same to check how it works
The short answer is that the Personal Edition doesn't really support frameworks. The best option would be to use the full version of Pega - your company/project might have a test system or someone with experience installing it.
You can try installing it as normal, but it might not work. Getting the full version of Pega running will probably be easier in the long run if you need Agile Studio.
To get media, you should open a Media Request type Support Request (SR) through the My Support Portal and ask for both Pega Platform and Agile Studio. If you haven't opened an SR before, one of the other people in your office/ on your project should know how, and be able to give you the name of your Account Administrator if needed so you can open SRs that are linked to your company.
Ryo Sakemi
Craig Tech
Will request and try with a test server.
JPMorgan Chase & Company
Please follow the below configuration steps
1) update your operator preferences
2) In the Designer Studio header, click the name of your current application, and click Definition.
3) On the Integration & security tab, in the Agile Workbench integration section, click Configure integration. 4) Select Pega Agile Studio.
5) Fill API URL for Pega Agile Studio URL and connect
6) Feed in product ID and Release ID so that created User stories and Bugs go into this and release is tagged
7) Click Begin integration.
8) Click Done.
Hi Yapas,
all the steps you have mentioned here are seen in the help file, I was looking for the exact values what should be filled in two things, can you please help on this
1. what should be filled in Operator Preference -- from where we get this value
2. what should be filled in API URL for Pega Agile Studio URL to connect--- for example if Agile Studio is installed on http://xxx.xxx.xx.xx:9080/prweb/PRServlet and I able to login using AgileStudioSysAdmin and SrProjectManager
1. Operator preference - any valid operator id on the agile studio system
2. Api url - http://xxx.xxx.xx.xx:9080/prweb/PRRestService/api/v1
Try the above , your integration should be succesful.
