Infosys
Last activity: 3 Aug 2017 4:40 EDT
Issue with declare expression
We are using a declare expression on a property. However we could observe that the error message dissappears when we click on the field. This happens only for properties which are used in a declare expression . The Pega version is 7.1.9
Coforge DPA Private Ltd
Hi Binod,
Can you attach the screenshot of the error you are facing so that we can resolve that.
YaswanthR
Infosys
Attaching the document with screenshot
Hi Binod,
A screenprint of the declare expression (if possible) might help.
Thanks.
Infosys
Virtusa Consulting UK
Hi Binod, I was requesting you for a screenshot of the rule, not the error. The reason was to understand if the property used in the declare expression is a source or a destination property. If you can clarify that pls.
Infosys
Kautuk,
This is a source . For example if there is a declare expression using pyFirstName and pyLastName . Using these properties will result in the mentioned behaviour
Infosys
Can someone please respond to this?
