Cognizant technology solutions
Last activity: 4 Oct 2018 5:58 EDT
Can we connect to https on port other than 443 from connect-soap ??
if we try from other port it other than 443 it looks like pega doesnt try to connect to endpoint. plz help.
***Moderator Edit: Vidyaranjan | Updated SR details***
The SR was resolved with the below explanation.
You can run HTTPS on any port if it's configured correctly. Configure the ISA server (a networking and security program that runs on Windows Server) to allow HTTPS connections through the port you are using. The best thing to do is to talk to Windows Server admin to have them open the ports. Or, you can use the default port of 443 - generally, there's no reason to change the default.
Thanks!
